Question about Kurio 7" Tablet with 4GB Memory for Families and Kids
It stays on a blackscreen - Kurio 7" Tablet with 4GB Memory for Families and Kids
Circircuit diagram for led driver board led blinking on D4 lg tv 55le5400 no picture blackscreen
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 22, 2016 | LG Televison & Video
Tip
My laptop shows blackscreen so i reformat it and now its not anymore showing the...
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 15, 2010 | Computers & Internet
How to clear blackscreen for windows 7 before login
Hello there anvesh_t416 if i got it right you have a blackscreen of "death" if you can get into safe mode, Navigate to the Start -> All Programs -> Accessories -> System Tools program group then click on system restore and see if it gets to a point that this stops. If you cant do that then your only option is to format your pc...
Mar 12, 2013 | Computers & Internet
Blackscreen on start.no display
Try the extension RGB monitor socket on a monitor to see if that works. If it does you might have hit the function key to switch the display to externel. Look in your manual about switching displays this will help you.
It will be something like <function F4 or something similar.
Dec 31, 2012 | HP Pavilion dv2000t Notebook
My gateway MT6919 comes to a blackscreen when i turn it on. I have replaced the motherboard. Still a black screen. I replaced the invertor and still a blackscreen. I'm not sure what to try next I...
You could have a faulty CCFL lamp that provides the back light.
If you view the LCD screen at a sharp angle and you can see a dim Windows image. Also if you connect an external monitor to the laptops VGA port power up the external monitor then boot up the laptop and you get a normal Windows image on the monitor, then it is a faulty CCFL lamp.
Replacement CCFL lamps are available from this WEB site.
www.lcdparts.net
Jul 14, 2011 | Gateway MT6919 Laptop Charger...
Blackscreen problem when viewing pictures it will show 5 to 10 pictures and then a blackscreen will appear. however, the computer will still be working.
If you move backwards in your picture viewing program of choice, (eg Irfanview, ACDSee or the inbuilt windows picture viewing program) does the previous picture work Ok?
If so, it maybe that the picture that is next in order is corrupted. ie it will make the screen go 'black'. if the picture works one time but not another time, its not the picture file at fault.
If you look at the folder with the View options set to Thumbnail, do all the pictures appear OK? ie in miniature?
Does the screen play up when playing a game or doing something else? If so, then the graphics chip on your laptop motherboard maybe on its way out. if you are lucky, that model laptop may have a replaceable graphics card. See the Dell forums for help, or give Dell a ring.
Cheers,
Steve (Melbourne, Australia)
Apr 14, 2010 | Dell Inspiron E1505 Notebook
Rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
Jun 01, 2009 | RCA L32HD31 32 in. LCD HDTV
Wont completley load up just ends up to a blackscreen
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 22, 2009 | Fujitsu LifeBook A3040 Notebook
Monitor blackscreen
If you have access to an external monitor then conncet that to the external monitor port. Holding the function key and F7 or F8 should switch the computer to the external monitor. If this is OK then I'd say your mercury lamp has burned out. If no access email back the beep code. You'll have to listen carefully. In either case this computer will need to be repaired by a reputable computer repair person.
Good Luck
Mar 22, 2009 | HP Pavilion dv9000z Notebook
Kurio 7" Tablet with 4GB Memory for Families and Kids Logo
60 people viewed this question
Top Kurio Home Experts
thinksewfast
 Mikey
Mikey
Mister Danger
Are you a Kurio Home Expert? Answer questions, earn points and help others
