Question about HP 285527-001 - Compaq Presario 900&Presario 1500 Series 8X Laptop DVD Drive (285527001DVDROM) CD-ROM Drive
Compaq pp2140 remove hard disk drive
Compaq pp2140
The original Hard Drive was 20Gb and the OS Windows 2000
Oct 26, 2013 | Compaq Computers & Internet
Compaq series pp2140 motherboard
whoo hoo.. got to the end of COMPAQ.
2012.
May 10, 2012 | Compaq Presario 900 /1500 Series EVO...
Does my Compaq series pp2140 have built in wifi?
go to compaq.com support they'll ask for your model number operating system xp or vista or windows 7. If its xp they have the driver download available all though I doubt if you need it unless you just installed the xp os. To answer your question yes it does if its ap 2140 there is no pp2140 that i saw.
Nov 27, 2009 | Compaq Computers & Internet
June 22, 2009 Dear Person, I have an HP-Compaq laptop computer, business model nx9010, s/n CNF3520KL4, with a failed hard drive. I am unable to remove the drive. I have removed the three (3) visible screws...
http://www.karlin.mff.cuni.cz/~motl/hp-keyboard/manual4700.pdf
PAGE 39
1. Unplug the AC adapter, if present, and then remove the battery.
2. On the bottom of the notebook, remove the hard disk drive rubber screw plugs and
M2.5×6.0mm screws. (The number of plugs and screws varies by model).
3. Carefully pull the hard disk drive out of the notebook.
4. Remove the four M3.0×4.0mm screws from the hard disk drive and hard disk drive tray,
and then lift the drive out of the tray.
5. Remove the connector bar from the hard disk drive.
The manual does have little picture to help you. The link above is to download the service manual.
Jun 23, 2009 | HP Compaq Business Notebook NX9010
Harddisk is not getting detected
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your
Apr 28, 2009 | HP Compaq Presario CQ60Z Notebook
Compaq laptop pp2140 missing vgaeon.fon
Try to press F8 on boot and "Safe mode" boot
Jan 11, 2009 | HP 285527-001 - Compaq Presario...
Compaq presario 900 series pp2140
yeah they are right, and i don't think they are acutally compatible
Mar 06, 2008 | HP 285527-001 - Compaq Presario...
Compaq Presario 900 Series PP2140 Power Up
Leave the battery out and try booting up on ac power only.
Jan 21, 2008 | Compaq Presario 900 /1500 Series EVO...
HP 285527-001 - Compaq Presario 900&Presario 1500 Series 8X Laptop DVD Drive (285527001DVDROM) CD-ROM Drive Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
