Question about Belkin (F5U237) 7-Port USB Hub
Usb hub doesn't work
--trying to use this on an HP desktop with 6 USB ports in back, 2USB ports in front, running Windows 7 with SP1 --power light on hub is on --devices recognized by computer when connected to other ports [or even the one the hub is plugged into] is not recognized when plugged into the Belkin --don't have administrator rights on this computer --could REALLY use the ports; how can I get this to work?
3 Suggested Answers
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Posted on Jan 10, 2011
  • 747 Answers
SOURCE: Belkin 7 Port Hub has power (red light is on). Has
unplug port and plug port back in and then restart computer.
Posted on Feb 01, 2011
Whenever i insert my external hard drive to the USB port of my desktop, the desktop flashes a message saying USB not recognize. And the hard drive does not work. i do not know to make it work..
The most common cause of this in my experience is not enough amperage available at the USB port. If you're using a front/top case port, try switching to one of the ones at the back of the case that is connected directly to the motherboard. If that doesn't work, you can use an externally powered USB hub, which usually solves the problem as long as the hub has a 2A or better power supply.
Hope this helps.
Sep 25, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
Hp pavilion a610y Describe your hp pavilion a610y usb port Problem: Message tells me to unplug my highspeed device from my slow usb port on my zboard keyboard and plug it into one of 6 unused usb ports in...
It is referring to the USB ports on the back of your computer near where your keyboard plugs in. The front ones must be USB 1.1 which will cause this error.
Apr 01, 2011 | HP Pavilion A610y PC Desktop
Machine will only respond with desk top not lap top computer when doing embroidery. why?
Could be a number of reasons, as I don't know what response you are/are not getting or what messages you're getting. First, do you have the same operating systems on both machines? (Windows XP, Vista, 7) There's a patch available for Windows 7 on the Futura website at www.Futura-support.com that should allow the Futura software to run on this operating system.
Another reason could be with the USB ports. Not all USB ports provide the same amount of power, and the Singer machine and USB cable require 12V. On a desktop, you normally have to have the cable plugged into the BACK of the computer, not into a front port or USB hub. If you're getting a message on your laptop that the cable isn't plugged in, then this is most likely your problem. If you're using a USB hub, plug the cable directly into a port on the back of your laptop. And if that port doesn't work, move to another port, trying each one on your laptop, until you find one that works. That port has the power that you need.
I hope one of these solutions works for you.
Oct 27, 2010 | Singer CE-100 Futura Computerized Sewing...
Why don't the usb ports work on the side of monitor
is there an extra cable, aside from the Power Cord, and the VGA Cable? if not, look on the back of the monitor, there should be a similar plug in like a USB printer would have, its kinda square. If there is, you just need a USB printer cable to make it work.
Oct 04, 2009 | HP Pavilion (PN153AAR) PC Desktop
Keyboard, mouse, front USBs,DVD recorder not working
It sound like your USB Ports is the problem. Go to the Hardware manager delete the USB Ports and then shutdown and power back up.
The system then should reinstall the USB Ports and associated drivers. If not the USB Ports were probably fried by the power outage.
Mar 30, 2009 | HP TouchSmart IQ770 PC Desktop
USB ports no longer working
After all done,
Did you think of replacing motherboard?
Feb 17, 2008 | Computers & Internet
Kodak easyshare 5300 issue.
Call Kodak tech support and they will ship you a new printhead without any charge.
Jan 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
May 24, 2007 | Rio S10 MP3 Player
Open Questions:
See all Belkin (F5U237) 7-Port USB Hub Questions
Belkin (F5U237) 7-Port USB Hub Logo
42 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
