Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
Ice maker dont make ice!
Wont come on wont make ice was shut off for days then when turn on didn't work. worked before shutting off.
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
aborcass
  • 2651 Answers
SOURCE: Ice maker flooded the house
how much water we talkin here a cup or gallons?? the icemaker will only call for water after dumping cubes,SHOULD at least, if only a cup of water or so id say the ice maker has an issue and needs replacing(its an entire module), there is a valve behind the machine energized by the ice maker, if htat got stuck open in which case water continued to flow overnight i would repalce both ice maker and valve
Posted on Mar 01, 2008
SOURCE: Whirlpool GD5RHAXNQ00 Ice maker not making ice
We had a similar problem and there was a broken/stripped gear in the icemaker. A&E replaced it to the tune of $150 or so. I don't recall exactly but I recall my husband thinking he could replace the entire icemaker for the price we paid to repair it. The gear make the ice tray flip out the ice once frozen. Good luck, hope that helps a little.
Posted on Jul 15, 2008
Sea Breeze
  • 4655 Answers
SOURCE: no water flow to ice maker
Two possible answers on this one. The water control valve for the ice maker is defective or the switches inside the front of ice maker are stuck.
Please send the model number listed for your refrigerator so I can help you find the ice maker switches and parts break down for your refrigerator. Below is my website address.
http://servicepartstec.blogspot.com/
Let me know if I can help you more, Thanks Sea Breeze
Posted on Mar 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Posted on Jul 14, 2009
I turned the ice maker off now I can't get it to turn on and work it freezes cubes but won't dump them in ice been
Ice maker harvest cycle is not working. Jammed timer in Ice maker unit.
Remove the wire harness of the ice maker and put it back after 5 minutes. See next day whether it is working.
If not still working. You did the right needed thing at the wrong time to shut off the ice maker. You will have to replace the ice maker.
Ice maker units are very sensitive units. Sorry to say.
Oct 23, 2017 | Refrigerators
Can you turn the ice maker off like other refrigerator ice makers? I didn't see anyway to turn my ice maker off or do I empty the ice out everytime?
Most ice makers have a control arm that raises and lowers to check for a full condition. It usually raises during the dump cycle and lowers during the fill cyle. If it is unable to lower (because the bin in full) it should shut off the fill cycle. If that function is not working, then if you move that control arm to the fully raised position, it should shut of the fill cycle, until you manually lower it again.
Jun 04, 2011 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice maker overfilling
OK i took a look at the ice maker. this has a shut off arm. i am guessing it always shut off automatically when you 1st had it right? but now it just makes too much ice. does it still do it if you lift the shut off arm up? if you lift it up and still makes to much ice then replace ice maker. (wait a couple of days)
if it stops making ice then just shut it off every other day thanks
Mar 28, 2010 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Ice maker not producing ice. Changed the water solenoid valve and the ice maker. still no ice! what is the problem here. how can i remedy this.
Good Day,
Obvious but,
Shut water off to house at the meter. Remove supply line to water valve. Place end in a bucket, have someone turn on main valve for a 15 second count. Should have a hard steady supply from the line into the bucket.
If no joy, and this is common,
Remove Ice maker and see if ice has built up in supply tube from outside back of machine into the rear of the ice maker.
If iced, defrost, but caution. Heat guns, hair dryers ect. can do more harm than good. Go slow.
I do not recommend heat because of all the plastic and vinyl. Just shutting down the machine by unplugging it, and air drying.
P.S. I've installed brand new ice makers and valves that didn't work out of the box.
Nov 18, 2009 | Kenmore Refrigerators
Ice Maker will not stop making ice
the beam is defective. Its called an optic eye it does tell the IM that the bins full and cuts power to IM when beams dont see each other.
Nov 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Ice maker has quit working
Sounds like the water port to the ice maker is frozen. Do a complete defrost - shut off power for at least a day or more then turn back on and see what happens.
Mar 25, 2009 | Refrigerators
You can take the cover off of the icemaker and with a pair of needle nose plires take off the dile and clean with an eraser. You probly can see the problem when you get the dile off. Let me know if that is works. Has worked for me in the past.
Dec 20, 2008 | Jenn-Air JSD2789GES Side by Side...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
15 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
