A circle with a diameter of 34mm find the circumference of it
The circle needs a circumference and i need the formula for it. And i need the area formula for it i also need the radius for the circle all i need to know is the formulas
SOURCE: Excel Formulas
Get on Excel web sight and look at Excel Tutorial close to bottom of page. Follow the instructions.
Posted on Sep 17, 2007
ccharacter
  • 16 Answers
SOURCE: getting the excel formula
Suppose the value for $ is stored in cell A3. Your formula would look like this: =(A3+A3*0.25)*1.5
The equals sign at the beginning of the formula is necessary. And if you want the result to be formatted as currency, you can do so by right-clicking the cell or column, format cell, number tab, choose currency.
Posted on Nov 15, 2007
Loringh
  • 185 Answers
SOURCE: formula for a percentage of something
the formula would be as follows:
X + Y%(X) = Z or 176.37 + .128(176.37)=198.95
If you were going to do this in MS Excelit would be:
assume 176.37 is in A! and the .128 is in A2 and the total will be in A3
A1 + A2(A1) = A3
Remember to multiply by percent, first divide the percent by 100
5% would be .05
Hope this helps
Loringh
Posted on Oct 17, 2008
label_chick
  • 407 Answers
SOURCE: EXCEL ALL SHORT FORMULA
You will find some help with formulas here
http://office.microsoft.com/en-us/help/HA102284301033.aspx
The shortest formula I can think of =A2+B2
Posted on May 22, 2009
hmerchant110
  • 7191 Answers
SOURCE: i have the fx-9750gii. how do i store formulas?
You can download the complete set of manuals available for this calculator by clicking on this link . There are 22 different chapters each describing a function in detail. Download all the chapters and save them for future reference.
Hope this solves your problem. Thanks
Posted on Oct 20, 2009
What is the area of a circle if the circumference is 2 pi inches
area formula is PI x r squared
that is 3.1417 times the radius of the circle squared
example is:- 3.1417 times 3 inches squared =3.1417 times 3x3=3.1417x9=28.279 square inches if you want to work back from a circumference measurement, the formula for circumference is 2 x PI x radius or PI x diameter
if you have a circumference of 12 inches then the dia is calculated 12 inches = dia x PI to get the diameter , divide the 12 inches by PI and that will be the diameter so that is 12 divided by 3.1417 =3.819 inches
now you can go from the first formula the radius is the diameter divided by 2 so the radius will be 3.819 divided by 2 = 1.909 inches
so applying the area formula it becomes 3.1417 times 1.909 times 1.909 =11.458 square inches
to find your answer simply substitute the dimensions in place of the example figures.in the relevant formula.
Aug 24, 2015 | Office Equipment & Supplies
15" circle what is outside measurement
If you would like to know the circumference of a 15" diameter circle this is the formula:
circumference = radius x 2 x pi
circumference = diameter x pi
in our case:
circumference = 15" x 3,14
circumference = 47 ,1" (that's 119,634 cm)
May 06, 2014 | Cars & Trucks
Formula for circumference
Circumference of a Circle: 2 x pi x radius - OR - pi x diameter,
or if you need some sphere calculations?
Sphere Surface Area: 4 X pi X radius squared OR
pi X diameter squared Sphere Volume: 4/3 X pi X radius cubed OR
( pi X diameter cubed ) / 6
By the way.......... "pi" = 3.1415926536
Apr 29, 2014 | Office Equipment & Supplies
What is the circumference of a circle with a radius of 10 2/7 feet. Use 3.14 as pi.
Using the formula: C = Pi * Diameter ..... where Diameter = 2* radius
Your circumference is Pi x 2 x 10 2/7 ft
Mar 03, 2014 | Computers & Internet
How to solve the circumference by using fomulae p=2
The formula is simply this: C = (pi)d. In this equation, "c" represents the circumference of the circle, and "d" represents its diameter. That is to say, you can find the circumference of a circle just by multiplying the diameter by pi, which is an approximation of 3.14.
Jan 30, 2014 | Computers & Internet
Circle equation
If you know the center, measure the distance between the center and one point on the circumference. Measure with the opening of a compass and report on a ruler, or use a ruler.
Take the measure of the radius and multiply by 2. Any other indirect way of getting the radius does not constitute a measure but a calculation.
The diameter of a circle enters in two formulas.
Length of Circumference: C=Pi*D (D diameter) ====>D=C/Pi
Area of the disk A=Pi *D^2/4 =====>D=SQRT(4*A/Pi), SQRT is the square root operation.
Dec 31, 2013 | Office Equipment & Supplies
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what...
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
Jan 31, 2011 | Computers & Internet
What is the radius of a 30'' pipe
30" diameter? Radius is 15" (half of diameter).
30" circumference (distance around) is a little more complicated...
The number pi.gif is the ratio of the circumference of a circle to the diameter. The value of pi.gif is approximately 3.14159265358979323846...The diameter of a circle is twice the radius. Given the diameter or radius of a circle, we can find the circumference. We can also find the diameter (and radius) of a circle given the circumference. The formulas for diameter and circumference of a circle are listed below. We round pi.gif to 3.14 in order to simplify our calculations. diam_formula.gif circum_formula.gif
Nov 17, 2009 | Gateway FPD1975W 19" LCD Monitor
Example of program in c++ and there code
Hello my friend, I am Jonas I work as a programmer in some various programming languages. Here try this code:
This program is design to output the Diameter, circumference, and area given a radius of a circle. #include <iostream.h> int main() { int radius, diameter, circumference, area, pi; cout << " Enter the radius of a circle\n"; cin >> radius; pi = 3.14159; diameter = 2 * radius; circumference = 2 * pi * radius; area = pi * (radius)^2; cout << "Diameter formula executing.....(2 x r)\n"; cout << "Diameter is " << diameter << endl; cout << "circumference formula executing.....(2 x pi x r)\n"; cout << "circumference is " << circumference << endl; cout << "area formula executing......(pi x [r x r])\n"; cout << "area is " << area << endl; return 0; }
Also if you need tutorial you can visit this site Learning C++ .Hope this solution will able to help your problem solved. If you need more assistance just reply to this post or send me a mail at geo_jonas@yahoo.comThank you and Godbless.
Jul 09, 2009 | Computers & Internet
What is the area of a semi circle the diameter is 2.500mm the radious is .425mm the circumfrence is 3000mm
You cannot have a semicircle that has a diameter of 2.500 mm and a radius of .425mm and a circumference of 3000mm
Circumference is equal to pi times the diameter. pi is = 3.14
The radius of a circle is always 1/2 the diameter
Area of a circle is pi time the radius squared
Loringh
Oct 30, 2008 | The Learning Company Achieve! Math &...
Computers & Internet Logo
David Payne
David Payne
