What source would the TV go on to hook cable to brand Phillips
3 Suggested Answers
  • 380 Answers
SOURCE: I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
Posted on Dec 08, 2009
SOURCE: Hi, my Phillips was hooked up and working fine
Hey, I'm Seth. I work as a sub contractor for dish network. I am picking up that your problems are on TV 2? If so, you will need to go into the menu on the TV itself and look for, "channel scan" or "auto memory". Run a scan. If there are no channels found go back to the "channel scan" screen. You will see an option saying, "air" or "cable". Switch it to the opposite of whatever it was previously on and run another switch. It should be found. I hope this wasn't too confusing, good luck.
Posted on Aug 07, 2012
Hi-Def TV does not sinc with DISH VIP 922 receiver?
I am lost on ur question, do u mean the TV will not show anything from ur Dish? I always use HDMI cables, quick and easy hook up. now when u use HDMI cable u will need to go into your TV menu or look on the TV (Sanyo, Phillips,, etc) remote and locate the Input, Source, Antenna button. and go the the correct video stream that u have hooked up to on back of ur TV. U should see HDMI 1 HDMI 2 etc choose each one till u get a picture.
Jan 01, 2015 | Televison & Video
Hooking dvr up to tv with a 15pin svga tv says change source resolution?
I have several DVRs, and have had similiar problems. I would first plug the DVR into a monitor and make sure it works. If so, then while you can see the menu, change the resolution.
Oct 27, 2017 | Philips Lm181e06 Lcd Panel Grade A Lg Dell...
My system is hooked up to TW Cable using the Component 1 connections. I don't get any PIP/POP picture or ability to view two different channels simultaneously
I believe you have to have two different input sources and then select which sources to use the PIP option. That's the case with my phillips tv. Hope this works for you.
Jan 04, 2011 | Mitsubishi VS-50111 50" Rear Projection...
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Component cables on HDTV not working
have you tried hooking a different video source upto to the tv to make sure it is not the dvd player that is not giving a signal to the tv?  Like an Xbox 360 or anything else with component output.
May 13, 2009 | Samsung TX-R2678WH 26" TV
How do I hook the tv up to the speakers?
we had to hook sound cables from DVD player into digital cable box, not tv and now surround works in tv mode as well as dvd.
Dec 26, 2008 | Curtis DVD5091 Theater System
Phillips dvd player
i need to figure out how to burn a dvd with my phillips hdmi recorder.
Sep 13, 2008 | Televison & Video
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
New
Try to connect TV AUDIO OUT to TV AUDIO IN or AUX IN on receiver, when you get sound from TV, select SURROUND mode on receiver.
Sep 30, 2007 | Samsung HT-X40 System
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
