SR 2000 ELECTRONIC SCHOLAR
THE KEY DOES NOT SEEM TO PRESS HARD ENOUGH TO LEAVE THE INK ON THE PAPER. IT WAS BARELY PRINTING THE TOP OF THE LETTER, AND AFTER I MESSED WITH IT, IT WAS WORSE
checkitright
  • 1362 Answers
SOURCE: Printing on Stationary with an HP Laser Jet 1320
Most printers and copiers are made for the standard 20# paper, if using a different paper then most of the time you need to specify what type ie: transparency, labels, lbs etc. so the machine can accommodate itself. ( lowering or increasing the heat in the fusing section, and pressure on the paper.)
for that machine everything is done through the pc. go to File, Print, right click on the printer, go to properties got to device settings, General, printing preferences and paper quality, there is a box there for paper options. try setting it to cardstock.
Posted on Oct 11, 2007
  • 186 Answers
SOURCE: KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Posted on Nov 15, 2007
SOURCE: no print - Brother EM-530
You need to take your ribbon and correction tape out and put them in again, something may have gotten crossed. I know I have done that before. (Sometimes one or the other is put in backwards)
If this doesnt work, you may want to try re-setting to the factory settings of the machine to see if that is your problem. Turn off the machine, hold the Code, Shift & Tab key all at the same time. Keep holding them down while you turn the machine back on. You will here a few rapid beeps. That lets you know it has reset. You will need to fix your margins and tabs to your liking again.
-If for some reason you reset and you get the wrong symbols when you type, change your keyboard setting back to "I" (lights at the top left should tell you if its under "KB" (Keyboard) I, II, or III) turn off for 10 seconds and turn back on. I hope this helps!
Posted on Apr 24, 2008
  • 39 Answers
SOURCE: my printer is running the
If you have a laser printer, it is probably going to be a problem with the fuser. That is not something that you want to attempt to fix yourself, unless you are very technically inclined.
If it is an inkjet printer, you may have a leaky ink cartridge along with other problems. The leaky ink cartridge can cause the ink spots. However, with an inkjet printer, I'm not really sure what will cause it to print words on top of words unless you have a paper feed problem and the paper is not advancing at the speed it normally would.
Posted on Nov 24, 2008
  • 3594 Answers
SOURCE: AE-710 Letter Keys Do Not Work
Check the pitch selector switch if it is in PS this will cause this problem.
DickyO
Posted on Dec 30, 2008
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Trey 1 is giving a message out of paper when they is paper inside
The message "No Paper" will appear on the LCD display if the Brother machine does not detect paper in the paper tray(Tray#1 or Tray#2) or MP(Multi-purpose) Tray.
Resetting the Brother machine may resolve this issue. To reset the machine, unplug the power cord from the AC power outlet for approximately 10 seconds and then plug it back in.
Note
For MFC users :
The Brother machine can be powered OFF for up to 4 days without losing faxes in memory.
If the message "No Paper" continues to appear on the display follow the instructions listed below:
When printing from Tray#1 or Tray#2 :
Pull the paper tray completely out of the machine. Go to STEP2.
When printing from MP Tray :
Go to STEP4.
Note Tray #2 is the optional LT-5300 paper tray.The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cut out.
2. While pressing the blue paper-guide release lever, slide the paper guides to fit the paper size. If the back of the paper tray doesn't move, the tray lock button may be in the lock position; slide the lock button to the unlock position and pull out the back of the paper tray again. With the paper removed, you will see the LTR (letter) marking on the plastic plate on the bottom of the paper tray to indicate where the moveable rear guide (with protruding arrow) should be moved to for letter size paper. There is also a marking for legal size paper. Make sure the guides are set at the correct mark. Reload the paper in the paper tray. Make sure the moveable rear guide does NOT push tightly against the paper. It should be adjusted to the LTR (letter) or LGL (legal) position, depending on your paper size. If the moveable rear guide is pushed too tightly against the rear edge of the paper, the paper will get stuck in the tray and a loud plastic snapping noise may be heard when feeding paper.
3. Move the tray lock button to the lock position (slide the button towards the paper).
4. If there is no paper in the tray, reload the paper.
The tray can hold up to 250 sheets of 20lb paper. Do not overfill the tray. There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic.
Note
If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed tray. Make sure you insert the paper far enough --about 1 inch- under the gray plastic bar in the MP Tray until it stops or it will not be fed and the machine will display the message "No Paper".
5. Verify the correct size and type paper is being used:
If you are printing from a PC and using the paper tray, make sure that MP Tray is NOT selected in the application's print properties for Paper Source.
If you are printing from a PC make sure that the MP Tray is selected in the application's print properties for Paper Source.
Note: Please be aware that the setting in the printer driver will take priority over the setting made on the control panel.
14. If you have set the Tray Use settings for a particular tray, the machine will feed paper only from that tray. If the selected tray is out of paper, a "No Paper" message will appear on the LCD. You need to reload paper in that tray.
To set the Tray Use setting, follow the steps below:
a. Press Menu.
b. Press the up or down arrow key to select General Setup.
c. Press OK.
d. Press the up or down arrow key to select Tray Use.
e. Press OK.
f. Press the up or down arrow key to select the mode you want to use.
You can select Copy, Print or Fax(MFC users only).
g. Press OK.
h. Press the up or down arrow key to select the tray.
You can select Tray#1 Only, Tray#2 Only or MP Tray Only.
i. Press OK.
15. For MFC users :
To test, print the Help List.
. Press Menu.
a. Press the up or down arrow key to select Print Reports, and press OK.
b. Press the up or down arrow key to select Help List, and press OK.
c.Press Start.
For DCP users :
To test, print the User Settings.
d. Press Menu.
e. Press the up or down arrow key to select General Setup, and press OK.
f. Press the up or down arrow key to select User Settings, and press OK.
g. Press Start.
Note
If the problem still continues after following the above instructions,
I recommend you clean the Separation Roller, Pickup Roller and Separation pad following the instructions of the FAQ: My Brother machine mis-feeds paper.
Apr 21, 2012 | Brother MFC-8460N All-In-One Printer
Printer will scan but doesn't print all colors when printing
Hi Donald,
  • First,make sure you're printing on original Epson cartridges.
  • If the ink cartridges are old,replace them.
  • Select BEST as the quality setting.
  • For the best print qualities,use the Epson special papers which are highly designed for the best prints.
  • Make sure you load one paper at a time.
  • You may also need to do a print head cleaning on the printer to unclog the nozzles and enable smooth ink delivery.
  • Check whether the printhead needs cleaning by,
  • Turn on the printer.
  • Load a letter size paper that is plain.
  • Press setup.
  • Then press the< or > to select maintainance.
  • Press OK.
  • On the highlighted NOZZLE CHECK option,press OK.
Hope this helps.Thanks!
Please rate this answer.
Nov 10, 2011 | Epson Stylus RX580 InkJet Photo Printer
We have a 3 part carbonless contract which is printed on both sides. The 3rd page is barely visible when the original 3 part form is completed (filled out) by ball point pen. Is it the carbonless paper...
Carbonless paper is great, but it deteriorates with age.
(Nothing new here. )
I don't know that there are different sensitivity paper available, but usually to get a good result the paper should be on a flat hard surface.
Naturally the writer must press much harder than with carbon paper.
- Yes, I have once seen carbonless paper forms printed on the wrong side. -
May 11, 2011 | Xerox Carbonless Paper, 3 Part, Letter...
Bottom plate shows leaking ink
If the bottom plate shows leaking ink
1) Cause : Inside of the machine is dirty, printed paper may be smudged.
Action :
a) Press[ON/OFF] to turn on the machine, then remove any paper from the Autosheet Feeder and Cassette.
b) Press the Open Button to open the Paper Output Tray, and open up amd set the extension by pressing down the hollow on the front side.
c) Place the only one sheet of A4/ Letter-size plain paper in landscape, horizontally fol it in half.
d) Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
e) Use right /left arrows to select <BOTTOM CLEANING< from the <MAINTENACE> and press<OK>.
The paper that is loaded in the machine will feed through the machine and be ejected.
If protrusions inside the machine are stained, wipe off the protrusions using a swab or the like.
Important: Before cleaning, be sure to turn off the machine.
3) Cause :Inapproprite media type is used.
* Check to see if the paper you are printing on is too thick or curled.
* Note that smudging may occur at the top and bootm edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless printing.
Refer to the Printer Driver Guide.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
2) Cause : Paper Feed Roller is dirty.
Action : Follow the steps to Clean the Paper Feed Rollers.
Cleaning the Paper Feed Rollers consumes time , so perform this procedure only when neccessary.
A) Press[ON/OFF] to turn on the machine, then remove any paper from the Autosheet Feeder and Cassette.
b) Use [Feed Switch] to select the paper source to clean.
c) Use right and left arrow keys to select <Roller Cleaning> from tbhe <Maintainnace> and press<ok>.
The Paper Feed Roller will rotate as it cleans.
d) Repeat steps c) 2 times.
e) Press the Open button to open the Paper Output Tray, and then open up and set the Paper Output Tray Extension completely by pressing down the hollow on the front side.
f) Load three or more sheets of A4/Letter-sized plain paper lengthways in the paper source you selected in step b.
g) Repeat step c) 3 times.
The paper that is loaded in the machine will feed tthrough the machineand be ejected
If there is not signes of imporvement after performing 3 times, contact the Canon Customer Care Center.
Nov 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Keys are striking the paper but no black ink is printing on paper
If tou put in a two part form and it types on the second form the ribbon is either empty of not lifting up. If it isn't lifting up there is a large black gear on the rt. side of the printer, wiggle it back and forth they sometimes jam tooth for tooth.
DickyO
Dec 19, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Ink won't dry
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Apr 28, 2007 | Canon i860 InkJet Photo Printer
jasbo
jasbo
