Question about Sony STR-DG600 Receiver
Display dims on certain menu items
When going through the menus to program the receiver, certain menu items are very dim to the point that you can barley see the display.  Then you move to the next menu item, and the display is bright again.  Has anyone else seen this issue on the str-dg600?
  • 757 Answers
The display will dim for certain features that are not available for use in your current configuration or current operation.
For example; if you do not have an antenna plugged in then the selection for the tuner will be dimmed on the display.
Posted on May 09, 2009
How do I open an .xls file in 64-bit version of excel without it being in protected view?
I was like that when the problem exists when double-clicking in Windows Explorer. Then I get the message that the program isn't responding and have the option to close or wait. After a few moments Excel does eventually open and I can work on the file. I do not have the problem when I open the file directly form Excel.
Read here, perhaps this article will help you - Excel Restore Toolbox http://www.excel.restoretools.com/
Apr 25, 2015 | Microsoft Excel for PC
Compaq pressario cq40 108tu ...display issues
I have come across this problem, the backlight behind the LCD dims without warning and the only way to fix this issue is replace the backlight, a very difficult repair, mine like yours was a Compaq. Most professional will opt to replace the entire screen.
Mar 08, 2012 | HP Presario Computers & Internet
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
How to add items in combobox using database in vb6.0
There are 2 ways:-
you can set the recordsource in the properties for the comboBox to a table or create a recordset and loop through it adding one item at a time, see example below:-
Dim dept As String
Dim db As DAO.Database
Dim rst As DAO.Recordset
Dim qd As DAO.QueryDef
Dim varResults
Dim oMessage
Dim sQueryName As String
Set db = CurrentDb
mdbname.[Form_Name].Department.SetFocus
dept = formname[Form_Name].Department.Text
sQueryName = "Query_Name"
Set qd = db.QueryDefs(sQueryName)
' set up input field for query
qd.Parameters("field_from_query") = dept
Set rst = qd.OpenRecordset()
Dim recCount As Integer
recCount = rst.RecordCount
If recCount > 0 Then
With rst
.MoveLast
.MoveFirst
Do While Not .EOF
listBoxproducts.AddItem .Fields("pname")
listboxCode.AddItem .Fields("pcode")
listboxPrice.AddItem .Fields("pprice")
.MoveNext
Loop
End With
rst.Close
Set rst = Nothing
Set qd = Nothing
Set db = Nothing
Jan 13, 2009 | Computers & Internet
Dim Display
go into settings and change your contrast it may help the display
Sep 12, 2008 | Garmin Edge 305 GPS Receiver
Display on etrex Legend is dim
Have you tried Main Manu / Setup / Display and then adjusting the contrast?
Jul 07, 2008 | Garmin eTrex Legend GPS Receiver
Front Display Dimming - Almost Totally Gone
Check and see if you don't have a auto dim setting on or you changed Display setting.
I have same Amp and this happened to me also.
Feb 25, 2008 | Harman Kardon AVR 125 Receiver
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
Display light
I have the same problem. I'm pretty certain that the display is a fluro which just plain wears out - like a lot of microvave displays. I have just found out that the Oz agent is now Bosch, so I'll contact them & see if a display tube is a spare item or whether you have to get the whole detachable front. -- Greg
Apr 29, 2007 | Blaupunkt San Diego CD32 CD Player
Sony STR-DG600 Receiver Logo
231 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
