Question about LG WM-2277HW Front Load Washer
Lg washing machine start button only works part of the time?
2 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: washing machine wont start on any cylcle,
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
Start/pause button on lg wd-1438rd washer/dryer flashing and wash cycle will not start
try pushing and holding for 5 seconds.
rinse+ and pre wash buttons at same time.
that takes off child lock.
Nov 06, 2016 | LG Washing Machines
I have LG fuzzy logic 6.5 wf660. When pressing start button ,next time all water level lights are blinking. Machine not working.
See if you can lift the top of your washing machine by unscrewing it from the back and there should be a code and test sheet in there that is very easy to follow.
Jan 01, 2016 | LG Washing Machines
Start/pause button is not working on my LG washing machine. All other buttons are working fine?
Problem maybe that the START/PAUSE button has broken loose from the control panel. All the buttons are attached to control panel and "hinged" so when you press the button, the button presses a small button switch on the display control. You may have to order
the Control Panel.. Disassembly is required to inspect.
It would be least likely that the Display PCB is bad..
Aug 19, 2014 | LG WM1814CW Front Load Washer
LG WASHER LE CODE
Fix for Error Code "LE" on LG Front Load Washing Machine
I just had an interesting experience with our LG washing machine today. I found some hints for the solution online buried in some user forums, but I thought posting my particular solution here in a less cluttered blog might make it easier to find.
I had just run a load of laundry, emptied the machine, and reloaded. I put the detergent in and started the machine. After sitting for about 2 minutes with no activity, a "LE" error message appeared.
While the online forums indicated this might be a problem with a sensor, I was able to solve the problem by doing the following:
1. Press the Power button
2. Manually rotate the hopper 4 times clockwise and 4 times counter-clockwise.
3. Press the power button and run the machine normally.
Don't know if this will work for everyone, but it worked for me. If I keep getting the error message, I'll have to call LG and find out about this sensor I was reading about.
May 30, 2014 | LG WM-2277HW Front Load Washer
Washer won't start - sometimes
Jason, take a look at this link and follow the steps very carefully. Were insulated golves. How to Fix an LG Front load washer machine that wont spin
Feb 28, 2014 | Frigidaire Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
My LG washing machine has power but no light display and doesn't work. I washed a bathrug and when I returned the machine had power (makes a tone when the on button is pushed), but none of the...
I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
Oct 11, 2011 | LG WM2016C
LG WM-2277HW Front Load Washer Logo
14 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
