Question about Maytag Washing Machines
MAYTAG NEPTUNE MAH87000AWW Drive Motor RPM SENSOR
Can They HELP ME? ENGINE cRUus brand model DWS8003SK WASHER BROKE THE RING magnetized RPM SENSOR AND NEED TO SELL ME THIS RING TO REPLACE broke.Also need a belt Hutchinson 1411JMA 6 channel and dryer Maytag Neptune I require one sensor heat KSDO20 mark 200th CRJ model.
  • argenis alcantara
    argenis alcantara Mar 04, 2014
    Please can you find a MAYTAG NEPTUNE Washer Motor DWS8003SK model used? I need exactly the rpm sensor magnetic ring That is located on the rear of the engine.   My regards and I hope can help me! My email: argenisalcantara@gmail.com
  • 3 Answers
SOURCE: maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Posted on Jan 11, 2008
  • 5 Answers
SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
Posted on Jun 23, 2008
  • 160 Answers
SOURCE: Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
Posted on Jul 10, 2008
ngfam1
  • 639 Answers
SOURCE: Belt replacement for a Maytag dryer - Model No. DE410
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Posted on Sep 02, 2008
abhishek33
  • 1239 Answers
SOURCE: Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Posted on Sep 12, 2008
My Maytag Neptune washer is not spinning and I tried only Spin cycle for 12 minutes and gave LR error message. Pl help?
Hi, the Maytag Neptune front load washer LR or Locked Rotor error indicates and issue with the motor drive system. The motor control board is located near the floor on the right side. See Neptune Disassembly help to remove the door and front panel to get access, if needed.
I would unplug machine, remove all connectors and reinstall a few times and retry machine in case of any oxidation on the connectors. Also, check the belt and make sure it has not popped off. There is a rear access cover you can remove to take a peek.
In addition, there is a motor drive test you can perform to see if the inner tub will rotate at 50 rpms. You should have a document with your machine that instructs how to perform this simple test and it could be located in the top console.
Depending on which machine you have... If the motor control board has failed then you may have to replace the motor and motor control board since Maytag redesigned them because they were having reliability issues with them and they decided to change the motor technology they were using. See maytag maytag Neptune motor conversion kit for more info.
I hope this helps...
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
Apr 25, 2011 | Maytag Neptune Washer
Maytag neptune tl error op
You have lost signaling thru the Left Hand Lid lock or you could have a Lid Magnet out of posistion;
Google Neptune TL Washer FAV6800AWW
6 or so post down and I have service notes to help you troubleshoot.
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't drain
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
E3 error
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Aug 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
E3 code showing sometimes on Neptune MAH-3
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Jul 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
I think that you have a faulty motor. Are there any visible cracks in the stator? The rotor position sensor could also be faulty.
Apr 10, 2007 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
214 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
