Question about Sony KDS-55A2020 55" Television
How to clean fans on KDS55A2020 - Sony KDS-55A2020 55" Television
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
Tip
How to clean your Dyson Cool fan
How to clean your Dyson Cool AM01 or AM06 desk fan, AM02, AM02 Living, AM02 Mini, AM07, AM07 Living or AM07 Mini tower fan, or AM03 or AM08 pedestal fan.
Your machine may differ to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Cool fan before cleaning it. We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Cool fan as this could cause damage not covered under guarantee.
on Nov 27, 2014 | Dyson Dryers
My sony kds55a2020 wont turn on the green light flashes 7x then the red light flashes 4x
You have other power supply problems. The replaced lamp may have been good but the backlight power supply may still be bad
Sep 19, 2012 | Philips Sony Kds-55a2020 Kds55a2020 Lamp...
AsI have a sony kds55a2020 tv, I recently replaced the lamp because the lamp light was on. after I replaced the lamp, the tv power blinks 4 times and never comes on. what else can it be?
hi,
Check is the lamp is properly installed or not. If the tv was at working condition before replacing the lamp then then the new lamp is not properly installed. Check one more time. If you can then just remove the new lamp and insert it again. Make sure that the lamp is properly attached. And then check.
ok
Jun 11, 2011 | Sony KDS-55A2020 55" Television
Sony kds55a2020 no picture no sound green light on steady
sounds like a power supply problem, does it "try" to come when you switch it on? also try to switch off with the button on the tv, leve it for few minutes and try to switch on again.
feel free to contact me for further assistance if needed
regards
Feb 27, 2011 | Sony Televison & Video
The inside of my fan looks very dirty and I would like to take it apart to clean. Do you have any instructions on how to do that?
#1 CLEAN WORK SPACE
#2 PLACE FAN ON ITS CONTROL SIDE DOWN
#3 REMOVE PHILLIPS HEAD SCREW FROM HANDLE
#4 REMOVE NON-SKID COVERS
#5 REMOVE OTHER 2 PHILLIPS HEAD SCREWS
#6 REMOVE BLACK SIDE & CLEAN
#7 REMOVE YELLOW FAN COVER & CLEAN
#8 7/16 SPIN-TYPE DRIVER REMOVES FAN NUT
#9 CARE....WASHER ON OTHER SIDE OF FAN
#10 PUT FAN IN SOAP& WATER ....TAKE YOUR TIME
Oct 14, 2010 | Lasko 655702 Stanley Blower Floor / Box...
Need to clean fan ,all fasteners removed ,can't remove clips on expandable end of fan
mcdevito75 here, Believe it or not, I use a good quality spray cleaner like Mr. Clean, a spray that removes dirt and then you wipe clean, I use the sray, let it soak, then with a garden hose clean it off. The fan motors are sealed so you don"t have to worry too much of water in the motors, still don't direct the water hose stream directly onto the fan motors, also allow the fan to dry real good, out in the sun. I never had a problem with mine useing this technique of cleaning.
Jul 19, 2010 | Holmes Products HAWF2040 Window Mount Fan
How to clean my fan
u can clean ur fan by using a scrubber making ita little wet with sopy water then cleaning it with cloth.please be careful nt to make ur fans motor or electric circuit wet
Mar 30, 2010 | Lasko 3520 20-Inch Cyclone Fan
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
Sony KDS-55A2020 55" Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
