Question about Cell Phones
IRulu tablet stuc on android screen
Yesterday morning when i woke up, i tired to power it on. I did so, and i noticed it was taking an unusually long time to power on, and staying on the android screen. So i turned it on and off many times taht day trying to make it work and i also did a hard reset. i factory reset and also tried rebooting but when i rebooted, it did the same thing and did not come up just stayed on that screen. I have no idea what else to do.
hydetech
  • 113 Answers
SOURCE: raymarine e-80 chart plotter keeps rebooting
If you are experiencing problems with your C70, C80, C120, E80 or E120 display resetting itself, or randomly turning itself off, there are 2 troubleshooting procedures that may resolve the issue:
1. Ensure that none of the buttons are stuck under the edge of the display's front fascia.
When the Multifunction Display is first installed, or any time after the front fascia has been removed, it is very easy to get the edge of one or more of the rubber buttons trapped under the edge of the plastic fascia. This is particularly prone to happening if the snaps that secure the fascia to the display are not fully engaged around both the outside perimeter of the fascia, and the insider edge surrounding the LCD display.
E-Series display with soft key trapped under fascia.
You can free the buttons from under the edge of the fascia by applying pressure to them with a fingertip, and rotating your fingertip in a circular motion. When the button is properly through the fascia it should sit centered within its hole, and you should feel a positive "click" of the internal switch when pressing and depressing each button. If trapped buttons were found, releasing them will return the display to normal operation.
2. Reset the display.
Your display may require a reset which will erase any stored waypoints, routes and tracks.
If your MFD's menus are accessible:
Backup your personal data CompactFlash memory card. Please see Answer #1145, Backing up waypoint, routes and tracks on C and E-Series for complete instructions.
Once your data is backed up you can reset the display using this procedure:
  1. If your MFD's menus are accessible, perform a "Settings and Data" reset from the System Setup menu. Press the MENU key, then scroll down to the "System Setup" option, and toggle the track pad right.
  2. Scroll down to the "Settings and Data Reset" option and toggle the track pad right.
  3. Under the word "Factory Reset?" press the softkey corresponding to YES. The display will restart momentarily.
  4. The display should reboot into normal operating mode.
If your MFD's menus are not accessible:
You will not be able to backup your personal data. We can reset the display though using this procedure:
  1. Press and hold down the first soft key (next to the power button.)
  2. Keep holding the soft key down while the display reboots. A "Factory Reset" countdown will be displayed. Keep holding the first soft key until the countdown is complete.
  3. The display should reboot into normal operating mode.
Once your display has returned to normal operation you should check its operating software version, and upgrade to the latest version (if applicable.) The latest update for your model is 3.31. It will be displayed on the message that appears during start up. This is an important update because changes were made to the WAAS satellites and your E80 will not recognise the satellites without this update. Click this link to download the update: Raymarine V3.31 update.
You may need to create a free account if you don't already have one.
Posted on Mar 12, 2008
  • 7 Answers
SOURCE: sidekick 08 stuck on reboot screen, keeps rebooting
I know you think that T-Mobile customer care may be stupid, but there is a process when you call and they will get you to a Sidekick specific department that uses a troubleshooting flow to determine if the problem is fixable or if your phone just simply needs to be replaced.  Your phone has a 1 year warranty from the day you bought it and just in case it is extremely helpful to have the insurance added.  It is not fun having to shell out another $350.00 to replace something that you just bought if the warranty does not cover whatever the problem may be.  The deductible for a Sidekick is only $130.00 to replace.
Posted on Jan 12, 2009
AskariZ
  • 31 Answers
SOURCE: My dell gx-270 power keeps shutting down.
hmmm,
Dont worry just boot your computer using Bootable disk or windows installation disk, enter into Recovery console by pressing"R"
type the Administrator password if any or simply press "Enter".
At the command prompt type-"fixboot"
once done restart your computer normally.
Posted on Mar 25, 2009
  • 111 Answers
SOURCE: Unable to factory reset - all port lights stay on with just power cable plugged in
All port lights showing on a router indicate a bad control board in the router. I'd say it's toast.
Posted on May 25, 2009
aberry9036
  • 49 Answers
SOURCE: I have an ASUS Eee PC 900. It was working fine
One more thing you could try is taking the battery out for a minute or two, because the Eee uses the atom it has a fairly complex onboard power controller that can overclock / underclock the cpu. Sometimes this gets malfunctions and locks the PC up, the quickest way to fix it is to simply pull the battery for a short while and stick it back in. You may well have already tried this, but it'll be the first port of call.
Posted on Aug 04, 2009
Reset administrator password for irulu model S14
How to unlock my iRULU Tablet - VisiHow
visihow.com/R.how_to_unlock_my_irulu_tablet
Recover Android Device in case of Forgot password/pattern unlock an Android device .... My 8-year-old son locked his tablet and forgot his password on both his ... iRULU model ax101 stuck at the Android screen and cycle to the beginning ..
Mar 21, 2017 | Computers & Internet
How do i reset my irulu tablet
hold volume up, power button and home button. If you get 10 months life out of an Irulu, you are lucky. Cheap Chinese entry level toy with no support.
  • How to reset your 7 inch irulu tablet - YouTube www.youtube.com/watch?v=FzqiP1hOZTs
    • BY SIMON PROSPER
    • 2 MIN
    • 62K VIEWS
    2014-08-03 · Video embedded · Want to watch this again later? Sign in to add this video to a playlist. This video was uploaded from an Android phone
  • How do I factory reset a iRulu Android tablet? The screen ... www.askmefast.com > Computers & Internet > Software > Tablet Irulu tablet reset to factory settings. My sis have forgotten her password for her ipro android tablet.i have tried to reset it to factory settings using power/volume ...
  • IRulu_SystemResets < Wikilearn < TWiki twiki.org/cgi-bin/view/Wikilearn/IRulu_SystemResets System Resets . There are two types ... This did not reset the iRulu to its factory configuration. ... Tablet PC Android User Manual--user manual for another brand of ...
  • Related searches for reset my irulu tablet
  • Jun 02, 2016 | Irulu 2014 7 inch Android Tablet PC with...
    How do I reset my Irulu 7 Tablet, when I cannot get to my settings? Is there anyway I can wipe it clean and begin it again?
    You can do a usually do a factory reset by turning off the tablet holding down the power and volume up button and it should take you to a menu that you can factory reset your tablet. Use the volume up and down buttons to scroll up or down on the menu, and power to select. Hope this helps you
    Jan 17, 2016 | Irulu 7" 4gb Mid Google Android 2.3...
    Irulu Expro tablet. Where is the Bluetooth setting?
    iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 ...
    https://www.irulu.com/tablet/p-irulu-expro-x1plus-10.1-inch-quad-core-t...
    iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 Lollipop support Wifi OTG ... Bluetooth: 4.0 ... iRulu Google Android Capacitive Tablet PC(1) ... 1 Comments 0 or 0 people found the following review helpful .... Connect With Us.
    iRULU eXpro X2Plus series android 4.4 high-speed Octa Core
    https://www.irulu.com/tablet/p-irulu-expro-x2plus-series-android-4.4-hig...
    iRULU eXpro X2Plus series android 4.4 high-speed Octa Core Tablet 16GB ROM 10 points Capacitive IPS touch screen Bluetooth 4.2. $89.99 $179.99.
    Irulu Tablet - Android Forums at AndroidCentral.com
    Dec 26, 2015 | Tablets & eReaders
    How do I estart a blank screen irulu 10,1 tablet
    You will have to reset it if the power button gets no response. Just use a paper clip or small pin. Hold for 15 sec. Then release. Should boot normal.
    Jan 29, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
    How do I fix my blank screen on my irulu tablet???
    drain the battery then power cycle Unplug electric then hold power button in for 30 seconds, then reboot. If that doesn't work might be a lcd issue.
    Sherri allinonecomputer.com
    Nov 25, 2014 | Irulu 9 inch Android Tablet PC, 4.2.2...
    Tablet is stuck on the screen that says android
    You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
    To factory reset:
    1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
    Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
    How do you reset?
    The most common way to factory reset an android device is these method. 1. turn off your device 2. Press the your Volume up button and power button at the same time for a period of time 3. you will see the android image appear on the screen after that you will see some options 4. Choose the WIPE DATA/FACTORY RESET by moving your selection using the Volume buttons 5. Select it using the Power Button Then wait for it to finish the resetting process.
    Sep 23, 2013 | Irulu 7" Touch Screen 2gb Android 2.3...
    Cell Phones Logo
    32 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
