Question about Pride Jazzy Select Gt With 2 Batteries In Central Florida
Reset button doesn't work
When you push the reset button in, it has to go way in and then nothing happens
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Reset does not work
Did you hear a click when you push a thin hard object inside the pin hole? Follow the instructions on how to reset the Titan water heater so you do it the right way.If your water heater still doesn't work, you need to take it for repair.
May 09, 2012 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Pride Jazzy Select Gt With 2 Batteries In Central Florida Logo
20 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
