Question about Samsung Dryers
Samsug model DV419AEW chime is chiming when not in use. how to fix it.
SOURCE: my doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
Posted on Dec 30, 2008
SOURCE: Seiko Westminster Chime Clock; Model No. QQF150G Caliber 12105
Does this help
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
SOURCE: Disconnect sliding door chime 2005 Saturne Relay
On my 05 Relay I scratched the oxidation off of the switch heads and the contact plates on the door pillar. Worked for me.
Another fix I've read about is to take out and put back the PSD fuse. Then open and close the doors twice (with power button) for the computer to relearn the positions.
Posted on Feb 13, 2010
SOURCE: Same problem, I cannot shut off hourly chime. Men's model CG111M
On the CG 111M, the chime is turned off and on by pressing the start and reset buttons at the same time. Those two buttons are on the right side of the watch face.
Posted on Apr 10, 2010
SOURCE: 'Doorman' chimes keep chiming, without bell being pushed
I had the same problem - turned out to be a cordless phone nearby. If you have one, try moving the bell away from the phone or vice-versa. Another possibility is a neighbour with the same code. There are some jumpers you can move around to change this.
Posted on Apr 22, 2010
My Howard Miller battery operated mantel clock model 612-588, movement 354078F doesn't chime. My wife thinks she might have changed a setting or switch accidentally. How do I re-set it?
There is a switch from 'chimes off' and two variants. There is also a night clime cut off or volume reduction.
. CHIME MELODY
Use the switch with the symbols
OFF, WEST, and MELODY2
to select the chime melody according to the following settings:
O
FF = Silent
WEST = Westminster melody and full hour strike
MELODY2 = Ave Maria melody and full hour strike (Beethoven's Ode to Joy on select models)
. VOLUME CONTROL
The volume of the chime can be modified by turning the Volume Control knob.
5. AUTOMATIC NIGHTTIME CHIME SHUT-OFF
The movement has automatic nighttime volume shut-off or volume reduction options for a period of eight (8) hours after the switch is moved to the shut-off or volume reductions positions. This feature will automatically repeat at the same time every 24 hours. Use the switch with the symbols to select chime silencing according to the following settings:
Chime silent for eight (8) hours
Reduced volume for eight (8) hours
Full chime volume
Here is the manual
http://bigbenclocks.com/img/products/manual/quartzmanual.pdf
Nov 07, 2017 | SHE Home
How do you fix chime on hour instead of on half hour?
Hello Shirley Petty,
Because you specified no movement name,
make or model...
I'm going to assign myself the simplest movement
on this precious little planet...
The battery operated $82 pendulum
with GENUINE electronic chimes:
https://www.klockit.com/tubular-quad-chime-quartz-clock-movement.html
Solution:
REPOSITION those HANDs
to match
the chime strokes.
(boom)
Carnac the Magnificent
Mar 26, 2017 | Chime Home
Why does my Carlon Plug in Chime Model RC8253R keep going off?
Carlon Plug in Chime Model RC8253R?? What is this?
Jan 18, 2017 | Cars & Trucks
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
I drive a 1990 honda civic, there is no chime sound when I open the door with the headlights on, key in or out... is there supposed to be one, and if so, how can i fix it?
there are like 1000:1 posts on how to kill a chime.
must be some one beat you to it? LOL
and NO, the EX Civic has chime, not cheaper models.
but the key chime should work.
do you need the drawing of the ICU to trouble shoot it.
its free and in on the honda forum. 1000 of posts on topic.
Oct 31, 2013 | Vehicle Parts & Accessories
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
I cannot figure out how to syncronize the time and chimes for a Seiko model AQF 153B with Westminster Whittington chimes.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Feb 25, 2011 | Seiko Mantel Clock
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
May 18, 2010 | Seiko Mantel Clock
I need instructions on how to use and program a nutone door chime. Mine is a musical style for front door. I can change the chime to many different sounds, but have no instructions on how to use or program...
The 515N number is a transformer part number, do you have a photo of the chime you have? Is it wired or wireless? Is it a newer chime or and older model? Check Nutone's website to see what model you have, then search their site for the model you have. The model page will have an instruction sheet PDF file download of the instructions.
Oct 11, 2017 | Broan-NuTone Door Chime Kit by NuTone
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
