Question about Nikon COOLPIX L20 Digital Camera
Coolpix L22 battery door latch - Nikon COOLPIX L20 Digital Camera
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
SOURCE: Battery door and latch broken
Have used a 5-cent nylon cable tie for years on our CoolPix 990 and it never has failed, and still allows for battery changes. Looks a little funny to some, but is very functional. Don't know if your camera's design is similar enough for this to work, but it may worth trying.
Posted on Feb 06, 2009
Obertelli
  • 3006 Answers
SOURCE: Cover latch for battery door broken on my Coolpix
This is a really common problem affecting this camera and the near identical Coolpix 2100 (and a few others).
If I'm correct, then the door latch has nothing to lock into on the camera body because the corresponding catch has broken off. Depending on how the break has occurred the body either has one or two small plastic pegs just where you'd expect the battery cover to latch onto or even no pegs and just barely visible evidence of where the catch used to be. The two pegs (or the site where they were) used to form a small soccer goal shape. The top of the goal (crossbar) broke away and sometimes takes away one or both goalposts with it. I've successfully repaired six of these now for various family members and friends.
Both are an easy fix, and if you live in Europe and pay postage I'll do it for free (I'm in London). if you live further afield, my offer still holds good, but the postage may cost more than the camera is worth.
To do it yourself you'll need patience, a sharp craft knife/scalpel, a jewellers file, a miniature pair of long-nosed pliers with a wire cutter, thirty minute epoxy resin and a standard small paperclip. Regarding the jewellers file: this needs to be a flat profile and about 5mm wide (not critical) and about 1mm thick, i.e. about the same thickness as the paperclip wire, and must have cutting teeth on the thin edges as well: this is vital.
First, straighten the paperclip. It needs to be as straight as you can get it as it make the rest of ther repair easier. This will form the new battery catch, so you need to use the pliers to shape it. The new "goalposts" will have deep roots held by the epoxy redin, so start bending at the centre of the wire. You need to end up with a cross bar which is the same width as the original plastic one, which has sharp right angle bends down to each goalpost which will be longer than needed at first. The long nose pliers taper so you can grip the wire in the pliers at just the point where bending the goalposts down will result in a goal of exactly the right width. It is easy, but takes a few goes to get exactly right and you may need a few paperclips until it's perfect. Precision is vital to a good repair which looks original.
Next, you need to use the file and the craft knife. If the goalposts remain, then use the knife to cut them off flush to the surrounding edge. Using either the knife or the file, cut out two slots where the goalposts were so that they're as precise a fit as possible for the paperclip wire. If you look into the battery chamber there will be a few plastic strenghthening webs, so use both tools to cut these to allow the two goalposts to sit well down into the battery chamber. Go slowly and carefully as the more accurate you are, the better the job.
Next, test fit the new catch into the slots you have just cut. It needs to be a perfect fit and needs to lay comfortably and flat into the slots. You should be able to slide the goalposts right down until the crossbar almost touches the edge of the battery chamber. The crossbar needs to be parallel to the edge of the battery chamber. At this stage you may find that you have to modify the wire a bit or even discard it and start again.
Now mix up the epoxy resin, and using a suitable tool put plenty of it down into the battery chamber between the strengthening webs which you've just cut, basically fill the areas bounded by the remaining webs, and go much lighter with the glue as you get near the edge of the chamber where the battery door will close. You don't want to get glue right up to the edge. Be careful not to make a mess and don't get the glue everywhere.
Coat the goalposts with the glue up to within about 5mm of the crossbar and lay the wire into the slots, using your tools to push the roots of the goalposts well into their slots. This is where all the careful cutting and wire bending will show
Once complete, you should find that the new catch (goal) you have just made will slide comfortably down into the slots you've just made. At first, set the height of the crossbar by eye so that the underside is about 1mm above the edge of the battery chamber and wipe off even the tiniest traces of stray glue which get onto the exposed parts of the catch or onto the edge of the battery chamber. Test fit the door latch into the catch: the mixed glue is quite thick even before it sets and should just hold the wire sufficiently for you to determine if the latch fits it correctly. The thirty minute setting time will give you time to make fine adjustments to the exact catch position. When you're happy, leave the camera with the battery door open somewhere for about 24 hours to enable the glue to fully cure. Although you've used thirty minute setting epoxy, it's still a bit flexible and nowhere near fully cured at this stage.
Afterwards, the battery door latch should engage into the catch as if it had been made that way by the factory. Now try it with the batteries fitted. It should be perfect, but if not there's usually enough give in the wire for final tiny tweaks to the fit.
I hope this has helped you, just sorry that I've never taken any pictures of the process. Your camera is basic but is still beautifully easy to use and even the 2.1MP version produces stunningly good photos, so this repair is worth doing.
Please return the favour by rating my answer.
Posted on Jul 13, 2009
virtualhost
  • 2185 Answers
SOURCE: The latch on the battery door of my Nikon Coolpix
You can get that replaced or repaired thru the list of Nikon Authorized service centers near you area. Just click the link::
http://www.nikonusa.com/Service-And-Support/Nikon-Authorized-Repair-List.page
Hope this helps.
Posted on Dec 29, 2009
  • 64 Answers
SOURCE: how do i fix the
Nikon cameras say battery exhausted when they need new batteries, just swap out the old ones and it should be good to go.
Posted on May 24, 2011
Battery door dosen't stay closed
After you close the door hold it closed then slide it forward
Nov 19, 2013 | Nikon Coolpix L22 L-22 Black Digital...
My battery door cover doesn't stay closedbattery door
Push it closed with thumb .. hold closed..then slide forward
Nikon L22 camera will not power with new batteries
Clean the battery contacts and the contacts inside the camera with a rubber pencil eraser. Bub them until shiny. That may do the trick.
Nov 28, 2012 | Nikon Coolpix L22 Digital Camera
THE BATTERY DOOR IN A NIKON COOLPIX L24 WONT CLOSE
This is a clear design flaw. There are hundreds of similar incidents. Just try searching for "Coolpix L22 battery door" Nikon refused even to sell me a replacement door, and asked me to send the whole camera to them for evaluation. Dozens of sellers on ebay and ali-express are selling the replacement door, but not Nikon-USA. They do not sell it. So beware when working with Nikon that they do not stand behind their products.
May 18, 2012 | Nikon COOLPIX L20 Digital Camera
Nikon coolpix L22 display will not come on and lens will not open
Your battery may be drained. That can be because the camera's built in battery charger is not working, a defective battery or an electrical problem in you camera that is causing an excessive drain on the battery. I would buy an inexpensive external battery charger. Once your battery is charged, see if your camera works. If it does, you have solved your problem for less then it would cost to send your camera in for repair.
Jan 13, 2012 | Nikon Coolpix L22 Digital Camera
Latch on battery cover broken. Nikon L22 red I have sent it back to Nikon and they want nearly as much to repair as it cost! So much for warranty.
If you want to do the replacement yourself, you can order a new battery cover from
http://uscamera.com/l22.htm
Mar 12, 2011 | Cameras
How do I insert the batteries on my Nikon coolpix L22?
to see a comprehensive manual on how to do this, you can go to this website
http://www.nikonusa.com/pdf/manuals/noprint/L22L21_ENnoprint.pdf
here, you can see theoretical teachings along with diagrams.
please rate
Dec 24, 2010 | Nikon Coolpix L22 Digital Camera
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
23 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
