Question about Kenmore 63662 / 63664 / 63669 Microwave Oven
Kenmore 721.66227 Microwave Oven will not cook, lights up, makes a clicking sound . The clock will start to count down.
  • 579 Answers
SOURCE: Kenmore 721.63662300, 1200W
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try www.partstap.com
Posted on Dec 31, 2007
  • 43 Answers
SOURCE: Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Posted on Feb 03, 2008
SOURCE: Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Posted on May 01, 2009
SOURCE: Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Posted on Dec 31, 2009
  • 534 Answers
SOURCE: Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
Posted on Mar 31, 2010
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Microwave is 6 months old. clock won't light up. when i try to set cooking time the inside starts making a clicking sound and a light flashes in the top right inside
Sounds like the waveguide cover has been contaminated with food that has carbonised and burning.
Call a Whirlpool repair agent and get the waveguide cover replaced.
They need to be kept clean and leaving the door open after cooking helps to dry the moisture out in the cavity. Making it last longer.
Jan 23, 2011 | Whirlpool MH1170XS Microwave Oven
Our Kenmore Microwave Oven # 721.89941490 does not respond when the "start" button on the touch pad is depressed. All other functions of the oven work normally, including time set, count down, light,...
poosible burned contacts on cook relay mounted on circuit board; or, a defective solder connection(s) on same board. another spot to check in the door microswitches.
Aug 30, 2010 | Microwave Ovens
Microwave wont start but timer counts 3 secs and shuts off
Check the door latch mechanism the black nylon door catch may be broken.
Jun 19, 2009 | Panasonic NN-T993SF Microwave Oven
Microwave lights up but no cook!
Magnetron of your Microwave oven may be defective. If there is a fuse between the highvoltage transformer and to the highvoltahe capacitor check the fuse is blown off. If so replace the fuse. If it is Ok change the Magnetron.
May 06, 2009 | Microwave Ovens
The microwave cook time is counting down at an accelerated rate
does the clock need to be reset? check the door the latch may need replacing. also check the fuse inside the unit
Mar 30, 2009 | Maytag MMV4205 Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Kenmore 63662 / 63664 / 63669 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
