Question about Yamaha Electrical Supplies
Yamaha EF5000 not producing power
Runs fine, fuses are fine, not sure how to check the breakers. It was producing electricity just 3 days ago before cold weather hit with light drizzle. Need help fast! Got a job to finish.
ccrozier_agr
  • 36 Answers
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Posted on Nov 29, 2008
SOURCE: my honda ev6010 engine runs good, but stopped
I am looking for an EV6010 Honda generator. I know they stopped manufacturing them, but I would like to know if anyone has a leftover for sale?
rmhoch@hotmail.com
Posted on Aug 19, 2009
sal_kh_sab
  • 98 Answers
SOURCE: Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
  • 244 Answers
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
SOURCE: Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Posted on Jul 13, 2011
Dewalt dg6000 runs but will not produce electricity
A problem here to get spareparts fitted on youre engine has hopeful priority in your case. because of the partsdelivery almost are discontinued. beware on the costs of other parts .
Detail Detail
Oct 28, 2016 | Electrical Supplies
Husky 5000 watt generator quit producing power.
You could have a bad circuit breaker button. Replace that and see what happens.
Dec 24, 2015 | Husky Electrical Supplies
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
1996 yamaha royalstar electrical?
Hi, Sonia and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.starbikeforums.com/forums/14-royal-star/23673-no-electrical-power-when-key-turned.html
Re No electrical power Road Star Forum Yamaha Road Star
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Mar 20, 2014 | 1996 Yamaha Royal Star XVZ 1300 A
My unit was working fine until 3 days ago when the breaker tripped, I reset the breaker and worked fine for a day then tripped again when it tripped both the ac breaker andthe main in the trailer as well...
High amp draw can be caused by a few different things, so first check that incoming voltage to trailer is sufficient. (115 volts) Not unusual for some parks to install more hydro hook-ups on a feed line, and when all are up and running, your incoming voltage could be decreased. If your o.k. that way, then I'd start looking at the compressor circuit of your ac, in particular, the compressor start-up capacitor. The capacitor basically stores electricity and boosts it to higher voltage for compressor and fan start-ups to reduce current draw that will trip the breaker. Please have a knowledgeable electrician, or RV tech check this for you, as a capacitor can give a real good high voltage (possible fatal) shock, even when power is off to unit. I also suspect that the start relay has shorted (welded) itself due to high amp draw situation, and that is reason it comes on by itself.
Jun 21, 2010 | Dometic Rooftop RV Air Conditioner
B93-366 Indoor Unit Ours is mounted on the wall in a new room addition (3 years ago). Has worked fine. Used it with remote control a few days ago. It worked fine. Turned it off with remote control. next...
You will have to remove the front panel and check the fuse to make sure that it did not pop. Also check your breaker switch to make sure that your breaker did not pop. Those can be your really only two issues
Please rate
Jun 01, 2010 | Heating & Cooling
My generator is not producing power runs fine does not make power
Could be several problems on the gen set itself. Check to see if there is a surge protection breaker or fuse, depending on age. Make sure all connecting wires are secure and switches are not set to 240v instead of 120v if you are trying to use outlets.
Jan 04, 2010 | Coleman Powermate Powermate 5000W...
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Electrical Supplies Logo
20 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
