Question about Gentron Electrical Supplies
No start after turn off will not start with pull start or elec.
Why wont the engine turn over when cold?
Seems you had a low battery, Maybe something was left on, radio or interior light? Have your battery tested
Aug 13, 2015 | Cars & Trucks
Torro elec start just hums when I push start will not turn ovger
If you pull the starter rope, does the engine turn over OK? If it does, then the starter needs to be replaced... or if it's 12V, the battery may be dead.
If you can't pull the starter rope, either, then either the engine is seized or something is obstructing the mechanism - branches? Rocks? A rat's nest?
Mar 05, 2014 | Garden
I have a Miller Bluestar 185. Will not start with key. Put a new battery in it and it pull starts fine but won't with elec start?
check if 12v go on solenoid of starter when you turn key to start,mesure 12 v on starter when you turn key to start
if voltage drop to few volt,wire or connection are bad
Oct 31, 2012 | Miller Welding Tools
MY 1998 SATURN DOESN'T SHUT OFF FOR 30 SECONDS WHEN U TURN ENGINE OFF HELP
One thing I can think of that will do that, is if some one wire your radiator elec. fan motor direct where it runs all the time, the fan motor will act like a alternator, where it will put voltage out to the ignition system, and till it stops spinning it will power the engine elec. system, one way to check is disconnect the cooling fan elec. plug (harness) and start the engine, if it turn off right away that your problem.
Jul 26, 2010 | 1998 Saturn SL
Scooter wont start. will start with jump leads
neutral/safety switch might be bad. the safety switch that is controlled by pulling in the brake lever
May 11, 2010 | Motorcycles
I have an old whirlpoos elec. dryer whilch worked
it could be a broken drum drive belt, or a bad motor or motor start capacitor
Sep 18, 2009 | Whirlpool GEW9250P Electric Dryer
I have a craftsman zts 7500 zero turning radius 26 hp with a pull knob over elec.To turn on the blades.It also has an elec.raised deck.When I pull the knob to turn on the blades the engine dies.And when I...
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Elec water heater
first turn the breaker off there should be two covers on the font of the heater if you r just looking for adjustments u can take those covers off and there is usually a foam piece behind the covers pull the foam off and there should be a dial to adjust it
Mar 15, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Washing machine tripping elec's
Sounds very much like the program PCB (printed circuit board) needs replacing.
A job for a qualified engineer I'm afraid.
Sorry.
Feb 27, 2009 | Creda W120VW Front Load Washer
Electrical Supplies Logo
48 people viewed this question
Top Gentron Electrical Supplies Experts
Phil Walker
Phil Walker
Adam Plug
Adam Plug
M.R.
M.R.
Level 1 Expert
Are you a Gentron Electrical Supply Expert? Answer questions, earn points and help others
