Question about Miele STB 101 Mini Turbo Brush
How to detach
I can't detach the mini turbo brush from the hose
Detaching mini turbo head from Miele
Just a guess but I had to disconnect my wet dry vacuum. Turn it counter clockwise to take it off.
Nov 16, 2013 | Miele STB 101 Mini Turbo Brush
Can't detach vacumn hose from hose grip base to clean with canister.
turn it 90 degrees to release it , if you look you will see ( unless its reallly dusty ) 2 tabs that are inside the hose attachment itself
May 08, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
I have an old fantom thunder upright and need to take the bottom off it to see what is stuck in it. I don't know how to do this.
moz-screenshot.jpgI found a manual for the Fantom Stick Vac, model FS801 (your model may be different).
For "Cleaning Air Driven Turbo Brush", it says:
  1. Remove the turbo brush from the hose or extension tube.
  2. Slide locking latch forward, then tilt the top housing of the brush upwards. The top housing is hinged and will tilt up approximately 45 degrees only.
  3. There may be some dust, lint, hair, etc. on the turbine wheel. Remove as much of this as possible.
  4. You may also use the unit's hose with the crevice tool attached, and use the vacuum to remove any additional debris from the turbine.
  5. Ensure that the turbine wheel moves freely by rotating it with your finger. If the turbine does not rotate, call Customer Service for help.
  6. Once clean, close the top cover of the turbo brush and slide the locking latch towards the rear of the brush to lock.
There is also an image in the manual that might help. You can download the manual for free here.
Hope this helps!
Mar 03, 2011 | Vacuums
Dyson turbo brush on a DC 32Animal has no suction. All the other brushes such as mini turbo brush work perfectly
Check for something stuck in the head of the brush the little buttons with slot turn and open.
Feb 09, 2011 | Dyson Vacuums
How do I attach a mini turbine head to my dyson dc07 upright?
Remove the handle / hose / wand assembly like you were going to use the tools. The mini turbo brush will attach to the open end of the wand.
Apr 14, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush wheels are not spinngin
There should be a rubber belt that drives the brush roller(s) which may be broken. Should be able to detach plastic retainer on bottom of machine to check/replace.
Oct 09, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My Bissell TurboForce Bagless Turbo Brush doesn't work
clean the filters..on atop the dustbin, inside the dustbin bottom..and over the fan below..if not sqeaky clean you loose suction
Sep 07, 2009 | Vacuums
Proheat Plus turbo brush does not work.
No water or soap is coming through, what do I do?
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have the Eureka EZ Kleen upright. We have suction through the hoses but not the main vacuum. The brush turns fine but the vacume does not **** anything up.
THE HOSE BETWEEN THE DETACHABLE WAND AND THE BRUSH ROLLER AREA MUST BE CLOGGED WITH CARPET FIBERS. CLEAN IT OUT AND IT SHOULD WORK.
SFC ANDERSON, RICHARD T US ARMY
Jul 08, 2008 | Eureka Vacuums
Dirt devil ultra vision turbo model #087300
As it turns out I didn't clean the hose as well as I thought, The second time I fully removed the hose and found that where it bent was where my problem was. Along with a pen I found about three inches of dirt clogged in the hose. After removing the pen and dirt along with a new filter the vac works like new.
Dec 06, 2007 | Dirt Devil Vision Turbo W/Bonus Upright...
Miele STB 101 Mini Turbo Brush Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
