Question about Belkin (F5U237) 7-Port USB Hub
Belkin 7 port hub needs driver
Power light for the hub is on, but devices recognized by the computer thru other USB ports are not recognized thru the Belkin hub. Owner's manual [found online as PDF file] states that a driver may need to be installed; no installation disk was included with the hub, Windows device installer does not see the hub as a device, Belkin online support was no help. 1]-how can I see what devices are connected to what ports through Windows desktop? 2]- how is a hub detected? why is a driver necessary for a hub? 3]- does a driver exist, how can I download it, and install it? [I don't have administrator rights on this desktop computer, so I need clear instructions to communicate to the person who does] 4]- the owners manual states that the driver may need to be re-installed if the hub's connection to the computer is changed to a different port on the computer; how do I save the driver so I can re-install it again should that happen?
3 Suggested Answers
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Posted on Jan 10, 2011
  • 747 Answers
SOURCE: Belkin 7 Port Hub has power (red light is on). Has
unplug port and plug port back in and then restart computer.
Posted on Feb 01, 2011
The computer can not recognize drive (unknown USB device).
Method 1 - Unplug Computer So how did I finally fix the problem? Well, if you are lucky, it's a super simple solution! Try this method first and if it works, you'll have saved a lot of time.
Simply unplug your computer from the power supply. Yes that is it! Note that this does not mean just turning off your computer using the power button because most modern computers don't actually turn off completely and the motherboard will still get power. This is useful sometimes if you want to remotely wake up a computer, etc.
The motherboard is where all of hardware of the computer connects to, including the USB ports. Sometimes the motherboard needs to be "rebooted" because things can go wrong, i.e. all or some USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should hopefully be recognizing devices again.
So first turn off your computer using the Shut Down option in Windows or pressing the power button and then UNPLUG the PC from the wall outlet. Let it sit for several minutes and then plug it back in.
Method 2 - Update Device Driver If Windows is not able to recognize the device, you may also see in Device Manager that the device shows up as an "Unknown Device". You can get to Device Manager by clicking on Start and typing in devmgmt.msc or by going to Control Panel and clicking on Device Manager.
In that case, you should right-click on Unknown Device, click on Properties, then the Driver tab and then click Update Driver.
If this doesn't work, you can also try to download the driver for your device from the manufacturer's website. If the USB device is just a flash drive, then it's probably not a driver issue. However, if you are installing a USB printer, drawing pad, etc, then it might be worth downloading the driver for that specific device.
Method 3 - Restart & Disconnect USB Devices The next thing you can try is to disconnect all USB devices and then restart the machine. once you have restarted, try to connect the USB device that was causing the problem.
If that particular USB port doesn't recognize it, try another one. If the device is recognized by a different USB port, there could be a hardware problem with one of the USB ports. If no USB port recognizes the device, then keep reading because it's probably something else.
Method 4 - USB Root Hub Another thing you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties.
Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box. If you have more than one USB Root Hub listed, you need to repeat these steps for each one.
Click OK and then restart your computer. Try to reconnect the USB device and see if it is recognized. If not, go back to the power management tab for each one and check the box again. If it does recognize the device, then leave them unchecked.
Method 5 - Connect Directly to PC A friend of mine ran into this issue and the cause ended up being his USB hub. He only had three USB ports on his computer, so he bought a hub where he could connect an additional 8 USB devices.
I guess this proved too much for his computer and it just started sporadically not recognizing various devices. After removing the hub and connecting the device directly to the computer, it worked just fine.
We haven't really been able to find any other solution to this problem other than reducing the number of items connected to the hub. Actually, one other solution worked, but it meant having to buy a new USB hub with more power.
If you are having this problem with Windows 8 or Windows 8.1, then you might be in luck. Microsoft has released a fix for Windows 8 not detecting USB devices properly. Make sure to install this hotfix if running Windows 8.
Method 6 - USB Troubleshooter If nothing has worked so far, you can download the Windows USB Troubleshooter Fixit tool. It's a free tool that works with Windows XP, Vista and 7.
You can either have the troubleshooter fix the problems for you or select the fixes yourself. I would just let it fix them for you since the choices can sometimes be confusing and technical for the novice user.
Method 7 - Update Generic USB Hub If you are getting the Unknown Device error in Device Manager, you can also try one other thing. Open Device Manager and then expand Universal Serial Bus Controllers.
You should see at least one item called Generic USB Hub. On some computers, you might see two, three or more of these. Right-click on the first one and choose Update Driver Software.
When the update dialog pops up, choose Browse my computer for driver software.
Jul 10, 2015 | Transcend StoreJet 25 750GB USB Hard Drive
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
When my computer searches for new hardware, it recognizes it and then installs it as "Unknown Device" The device still will not work, however, because when I check it in the device manager it...
This device should be recognized automaticaly by the OS. There are some issues with Windows 7, though.
Make sure you are trying to plug it in a 2. USB port, rather than 1.1. This might cause you trouble (even though this will not be a problem if you have a new computer)
Connect the hub to the external powercord. Sometimes it is not recognized because the hub cannot drain enough energy from the port.
if you are using a desktop pc, make sure it is plugged in the rear usb ports and not at the ones up front.
refer to the manual for further assistance: http://www.dynexproducts.com/cms/documents/DX-B4PORT-B7PORT_09-0962_QSG_V4_ENG_Final_lr.pdf
May 22, 2011 | Dynex 7-Port USB 2.0 Hub
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
Hello, I have a Belkin 2.0 USB 7-Port Hub, and having trouble with it. When i plug it into my computer, nothing happens, there is no power light and ultimately it seems as though the device is dead. ...
You first need a CAT 5 cable to go to where your internet connection is, such as a modem or another router to your hub. Then you plug another CAT 5 from the hub to your PC. You need to feed internet to the hub then your pc will recieve a connection from the hub. And of course the hub does need power. Hope that's what you were asking.
Mar 09, 2010 | Belkin (F5U237) 7-Port USB Hub
One day the Belkin 7 port hub works the next day it doesn't
Your problems with the Belkin 7 port are not due to the Dell computer or the XP OS. To problem solve, select on USB port and stay with it, not the 2 top ports for your keyboard and mouse. 1. Plug in the power adapter, wiggle it about, widen the prongs, change outlets at the 120 v. end. 2. Use an simple hand magnifier and peer closely at the DC input plug and be positive that the center post and the minue side piece of metal if in firm constact with the plug. If cannot insure a firm fit, sligtly bend that tiny metal piece towards center. Option 2, use another adaptor with the precise voltage as the original and the idential pin that inserts into the module. 3. Use another or new USB connector.
This list does not imply a specific order of diagnosis. Your fundamental problem is the failure to delive DC power to the Belkin hub or to capture the hub to USB port signal. In a phrase, you gotta short somewhere.not an issue with the computer or the XP operating system. Bill Miller
Aug 25, 2009 | Belkin (F5U237) 7-Port USB Hub
Thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Nov 16, 2008 | IBM ThinkPad T20 2647 Notebook
My Laptop does not recognize Belkin 7-Port USB Hub(F5U237v1)
Try connecting it to another port or the one on the dock since some devices can be a bit picky about what port they get plugged into.
Mar 15, 2008 | Belkin (F5U237) 7-Port USB Hub
Belkin (F5U237) 7-Port USB Hub Logo
56 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
