Question about Sumvision Cyclone Micro 3 Media Player
Remote control not working properly
The buttons on the remote control not working properly. To try and get the buttons to work having to press/squeeze bottom right hand side of controller and then try action buttons
Need instructions to use the Dish NETWORK remote for on-off and volume control.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 03, 2016 | DISH Network Televison & Video
How can I hook up my insignia lcd tv model ns-32lb451a11 to dish network with dish remote?
Is the remote capable of controlling other items check the handbook for the dish system for TV control set up if possible
Dec 24, 2015 | DISH Network Televison & Video
What code can I use to program my Dish Network remote to control my Nakimichi NK12 sound bar?
To whom it may concern,
1.) Point the remote towards the desired device you'd like to control.
2.) Press and hold the "tv" button at the top right hand side of your remote until all the top buttons begin flashing red.
3.) Press the small red power button at the top of the remote one time.
4.) Slowly and repeatedly press the down key on the directional pad until your device powers off.
5.) Once the device powers down, at the bottom right hand side of the remote underneath the keypad.. press the # key.
The "tv" button will flash red three times, and then your remote is linked to the box.
dish guy
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brian_142c5ec89a7a3fda
May 04, 2015 | DISH Network Televison & Video
My on button not work?
Try pressing (squeezing) the case right next to the button with one hand and then push the button with the other hand.
Aug 19, 2014 | Tablets & eReaders
Not able to turn tv on with remote
First try changing the batteries.
Next make sure when you press function on the remote control the red light on the remote displays under tv
Next try a remote reset:
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Aug 24, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
My Sharp LC-32SB24U will not power on from the remote. It will work if you push the button on top. I have another sharp lcd in the house and I tried that remote also but it still will not turn on from the...
Jun 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
The TV does not respond to the remote control. I have replaced the batteries in the remote control
May 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Can't get the remote to work at all
First press the SAT button at the top left hand side of the remote and release. Now try changing channels. If this did not work press the menu button twice on the receiver. It will usually be behind a pop open door on the right of the receiver. I f your receiver does not have these buttons you can access the system info screen by pressing the power button on the receiver while holding down the arrow left or right key.
Once you have come to the SYSTEM INFO SCREEN press and hold the SAT button on the top left side of the remote until all lights across the top light up. Then key in a two digit number e.g. 01-16 and press the #key. then press the record button and the remote address for the location you are trying to control should change to the number you keyed in. If this is the second location tv that was giving you issues exit out of all the screens on the receiver location tv and go to the other location and try the remote. If it is the tv where the receiver is located then you should now be able to use the remote to maneuver the yellow cursor across the screen. If you need further assistance please let me know. Thanks for using Fix Ya.
Mar 18, 2009 | DISH Network IR Remote Control
SAT button it does not work, you can not turn on or off the DISH
Dec 11, 2008 | DISH Network IR Remote Control
Apple remote control
At the bottom of the remote is a small button that can be pressed by a pin or pen. Press it and the battery will pop out. Replace the battery and you will have a working remote
Mar 09, 2008 | Apple MA128GA Remote Control
Sumvision Cyclone Micro 3 Media Player Logo
Top Sumvision Audio Players & Recorders Experts
Paul Bade
Sock Puppet
Clive
Clive
Are you a Sumvision Audio Player and Recorder Expert? Answer questions, earn points and help others
