Question about Garden
Speeco pump only works in one stage the more powerful stage not working
We have 2 furnaces in our house, both on the braeburn 3200 model thermostats.
If you have a dual fuel system - gas/heat pump the heat pump should lock out at around 41 degrees depending on what the outside lockout sensor is set at. It may be that both the heat pump and furnace could be running at the same time if the outside lockout isn't working or there could be a problem with the thermostat. Best bet would be to have a service tech check it out. However if you want to check it out here are the terminals Terminations: R,Y1,Y2,W2,E,G,O,B,L,C. W2, E and B are the heating terminals for 2nd stage heat and emergency heat. First stage heat, compressor Y1 with B (reversing valve on heat pump) energized together. 2nd stage W2 energized for gas or electric heat . No power to Y1 and B when W2 is energized if gas. E can be energized with Y1 and B if you have electric heat or if you switch over to emergency heat, E will be energized.
Feb 02, 2016 | Heating & Cooling
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
Siemens avantgarde washing machin stopping at rinse stage
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Mar 23, 2014 | Siemens Washing Machines
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
What type of oil filter for a Huskee 22 ton log splitter with a 190cc briggs & stratton engine?
Filter #s
Fram 1653A
Napa 1553
Cross 1A9023
Baldwin BT839
Wicks 51553
Kd460, here are some crossover part#s for a replacement filter for your Speeco splitter. To answer your other question, yes hydraulic fluid will pour out when you unscrew the filter. You can drain the entire tank first in to a clean container and then re-use the oil or you can put a container under the filter and then change the filter quickly. The fluid caught by the container can then be poured back in to the unit.
If you have any questions, you can call us here at Speeco@ 800-525-8322
Thanks
Kevin from SpeeCo.
Mar 31, 2013 | Garden
We have bought a home with the wite rodgers thermostat 1f85-275 it doesn't seem to be working. on the top right of the screen it states 1&2 stages? anyway, help would be appriciated
Hi, this thermostat is for central heat and air systems that have more then 1 stage of heating or cooling. For example, your unit may have 2 stages of cooling, as in 2 compressors, or 1 stage of cooling and 2 stages of heating as used in commercial heat pumps. This is a multi-stage heat pump thermostat. It may be just a matter of programming the stat. If you can find a manual on it, this would help. If you open the cover, it should have directions on how to program it.Make sure you have power to everything, check all breakers to see if they may be shut of, even if you have a display, doesn't mean you have high voltage to run the unit. Make sure fan is in auto, and on heat or cool, and temperature set for it to come on. Please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
PS Your unit has 1 stage of cooling, and 2 stages of heating.
Nov 05, 2010 | Heating & Cooling
I have a 919.167780 2 Stage Twin V Portable
two different problems here! first when it trips the breaker and you try to reset the breaker and not turn off the compressor on its pressure switch it does not unload the air off the head of the pump when you try to start it again,,, ( when it shuts off normally you hear the air drain near the switch,, this unloads the pump to restart)
The most likely reason it is tripping the breaker is that the second stage (smaller cylinder) is not doing the work it needs to do and the first stage (bigger cylinder) is pumping more now!,,,, higher pressure on this side makes the motor work harder.
I would advise rebuilding both sides to get the pump back up to correct running levels it had new.
Feb 25, 2010 | Craftsman Air Tools & Compressors
Is the Bryant 661CJ030-A heat pump single- or multi-stage?
Single stage heat pump. But you must have a two stage tstat for backup electric heat. You single stage cool two stage heat. The second stage brings on the electric heat in case the heat pump can not keep up. Wiring goes r y w1 on most heat pump tstats are switchover valve or o terminal. W2 second stage heat or emergency heat. g is fan c is common terminal.Rus
Nov 11, 2009 | Bryant 463AAC008BA Air Conditioner
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
