Question about Hotpoint WMA50 Front Load Washer
Door locked light - Hotpoint WMA50 Front Load Washer
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
Hotpoint WD640 Door Lock Light not coming on
check the door peg is not loose or it is the door lock
Apr 22, 2014 | Hotpoint Aquarius WD640 Front Load...
Do you know how to fix the "door locked light"
The door lock light indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dome light and doors open light stay on when driving.
check you door switch buttons to see if they will each turn off the lights. Open one door at a time, push the door push button by hand and see if the lights go out. If they do, that is your probelm switch or the door is not closing tight enough to psuh the pluger button all the way in.
Apr 25, 2009 | 1999 Ford Taurus
Accident turned on self clean with door open
I tried pushing in the light switch again, and i pushed it in until it stopped, evedently it is a 2 postion switch, when the door locks it pulls the door up tight, and the switch must sense this, so after I pushed the toggle in flush the lock finished locking and while I was still holding in the light switch I pushed the stop/cancle button and the lock opened up,and vola we could use the oven again, we had pizza.
Apr 11, 2009 | Kenmore Kitchen Ranges
Door lock staying locked so door cant clamp on to the striker
Hello and welcome to FIXYA, it sounds like you have two problems, first the door ajar switches in your truck are sticking, and causing the ajar light to remain on, and second the door lock actuator is shorted and getting stuck in the lock position. To repair the switches, obtain a can of brake cleaner and spray the door latch of each door for about 3 to 5 seconds, then open and close the door 10 times to work the cleaner into the switches. To fix the lock problem, you must first pull up on the knob in the door panel to unlock it. Then remove the door panel, and replace the door lock actuator.
Feb 07, 2009 | 1999 Ford Explorer
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA50 Front Load Washer Logo
14 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
