Question about Samsung Stainless Platinum 20 Cu Ft French Door Refrigerator Rf217acpn
Water is pooling in the crisper drawers on my french door refrigerator
Sea Breeze
  • 4654 Answers
SOURCE: there is water pooling inside the vegetable
Your refrigerator has a defrost drain blockage behind the evaporator in your your fresh food compartment. Some models like yours have 2 evaporators. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution in the drain will help you locate the leak and where. I do have the manual on yours and can help you solve this. Let me know, Sea Breeze
Posted on Jun 30, 2009
  • 354 Answers
SOURCE: water filter on my side
Well first thing shut the water off,drain water out by removing filter ,check the o-ring on filter and if you recently changed the filter you possibly pinched it when reinstalling and now you need a new. If not it could have a flat spot on it and wore out either way you need a new on.Appliance store (get model # or take with to match up) or even at times a hardware store that sells o-rings.
Posted on Mar 27, 2011
heatman101
  • 43501 Answers
SOURCE: samsung refrigerator model#RF26VABP keeps pooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 06, 2011
  • 5370 Answers
SOURCE: Water is pooling under vegetable/deli
Its a defrost problem.Click this link below and follow the troubleshooting:--- http://technoanswers.blogspot.com/2011/07/water-is-pooling-under-vegetabledeli.html ---------- This should help.Thanks.Helpmech.
Posted on Jul 08, 2011
imufo2
  • 3773 Answers
SOURCE: Fridge is collecting water under the crisper
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 16, 2011
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
http://www.woolleys.com.au/?gclid=CPqQzujj184CFQYdaQod1n0AIw
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=121998338668&catId=20710&item=121998338668&mid=503315&sdc_id=1081525136346&sortbid=15&rmvSB=true
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
http://www.appliancepartspros.com/samsung-case-veg-assy-da97-08437d-ap5805507.html
Aug 23, 2016 | Samsung Refrigerators
Samsung refrigerator
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
My crisper drawers collect water
adjust your settings for what you keep in there...and you should be able to solve the problem
Oct 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Why is water pooling under right crisper?
On defrost refrigerators water is drained down the sides to an outlet on the bottom of the interior of the unit and then to a tray under the unit, close to the floor, where it is heated and evaporates.
If he hole inside is plugged then the water will pool inside.
Take out both crispers and try to find the location where the water will flow out. It may be plugged with gunk The inside bottom of the unit may have indented runs where the water will be directed to the outlet.
Oct 27, 2011 | Samsung RF217ABWP (20 cu ft) Bottom...
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Contents of crisper drawers are frozen
may be a faulty compressor. ours went out last week, covered by 5 yr warranty though.
this might cause over-cooling and frozen water dispenser as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Samsung Stainless Platinum 20 Cu Ft French Door Refrigerator Rf217acpn Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
