Question about Exercise & Fitness
I hear a knocking sound each turn of the peddles on my Advantage Fitness upright exercise bike. Works fine except for this knocking sound. Ideas?
SOURCE: I need an owners manual
Vital Fitness
Customer Service
5988 Peachtree Corners East
Norcross, GA 30071
888/337-2883 M-F 8-4:30 EST
Manual has assembly/maintenance instructions and a 1-page description of functionality. And a warranty card...that is printed on the back of the instruction page. *headslap*
kb
Posted on Mar 09, 2009
kingbenny325
  • 11 Answers
SOURCE: schwinn dx900 upright exercise bike--need
LR44, A 76 or equivalent
Posted on Nov 30, 2009
SOURCE: DOA Life Fitness 9500rhr exercise cycle
You should check your battery-it must be putting out at least 6 volts to get the computer started up-depending on the era there will be a battery near the bottom frame-you will need to remove on of the side covers to reach it-
Posted on Dec 30, 2009
SOURCE: Need Manual for Vital Fitness Exercise Bike RB26S
I have a manual for this model. I can not tell you how to find one, I have looked all over the net for additional info. on this model and can't find anything. Would be glad to scan and send you a copy if you still need it.
Posted on Jan 09, 2010
SOURCE: I have an Edge 491 Exercise bike and the control
Take a look at the battery compartment under the panel (left looking up). I had a similar problem and had just fixed it. Hopefully you can get the same results.
If the strip of metal with the spring is corroded, take the batteries out, and carefully remove the metal strip. I used metal duct tape and wrapped the piece of metal with the tape. Carefully put a slight bend in the middle of the strip and reinsert the strip. If the batteries do not connect up, bend the piece a bit more or add more of the metal duct tape. After doing this, the panel came back to life. If this is not your problem, then my apologies. If it is, then good luck.
Posted on Feb 28, 2010
Plug in the bike will run fine for a week then comes up e-1.will do it more all the time
Sounds like battery is worn out. It holds a charge for a while then dies. Remove battery, take it to Batteries plus for testing and/or replacement
Nov 12, 2014 | Fitness Quest Edge 482U Upright Exercise...
Life gear exercise bike
This bike looks to be of the Lemond Revmaster series.
first, dial the resistance knob back until the leather break pad is no longer touching the flywheel. Get down on the floor and postion yourself between the flywheel and pedal cranks. Slowly turn the cranks arms and listen and feel for a roughness in the bike.
This has bike has bearings and a belt. It should not make any noise.
Now with the right pedal at a 2:00 position tighten the resistance knob down all the way so the flywheel will not turn. Then get on and push very hard on the right pedal. If the belt is loose, the pedal will move. Austin Fitness Rentals Rent Commercial grade Fitness Equipment in... ">
May 16, 2014 | Exercise & Fitness
Chain keeps comming off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
We haven't used our expresso S2u in a while, just turned it on and monitor won't come on?
Check the connections....seem like you may need service...try www.techmotionusa.com or 877-805-1030
Sep 04, 2013 | Expresso Fitness S2u Upright Exercise Bike...
What's the best exercise bike there is?
According to me, one of the best Exercise Bike is Fitness form S20 Indoor Cycle Bike. It has adjustable resistance level and adjustable horizontal or vertical seats also. It provides the pulse, distance and speed or has roller wheels to move around easily. In this bike, you can also get a warranty of 12 months.
Aug 09, 2012 | Exercise & Fitness
What is a recumbent exercise bike?
Recumbent exercise bikes have an advantage over the upright exercise bikes because of the level of comfortableness and the position the rider is in while exercising. It's also easier for starter with back and hip problems and elderly people.
What's better a recumbent or an upright exercise bike?
Recumbent bike works best for elderly people with back and hip problems because of the relaxed position and the angle that put's less pressure on those areas. Upright exercise bike works on more areas than the recumbent bikes including the lower abdominal muscles.
The belt has come off inside the main unit. How can I separate the pedals to remove the panel?
This may help you ... bicycle peddles are usually left hand treaded so you have to turn the shaft with a wrench right to loosen and left to tighten.
Oct 10, 2009 | Fitness Quest Edge 482U Upright Exercise...
Exercise & Fitness Logo
37 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
