Question about Toys
5 facts about mercury - Toys
2003 mercury sable heater blows hot air out dash but when transfered to floor or defroster it blows out cold air tryed flushing system but didnt help ...any advice Confused
Not in the coolant system, you flushed
It is a failed HVAC Blend Door Motor, under the dash
The fact you have heat or A/C, but not in all 5 positions
or combinations, should have told you, the air flow is not
switching as it should
Oct 05, 2014 | 2003 Mercury Sable
1993 Mercury Tracer running hot
"rule out" questions - is coolant level OK? Any leaks, especially around the water pump? Has the system ever been flushed. out? If this is the original radiator, it could be clogged. Is the thermostat installed correctly with spring end toward the engine?
Mar 22, 2014 | 1993 Mercury Tracer
Info about planets
A simple Google search with keywords Planet Mercury would give you a plethora of webpages to discover. Here is one. Do not just copy paste. Rewrite, put you own spin on things.
Here is the link,
http://space-facts.com/mercury/
Jan 03, 2014 | Computers & Internet
Changed battery in 2088 mercury milan and engine light came on
you should have it hooked up to a computer. whatever the problem is, it may not have anything to do with the fact that you chaged the battery but could just be that a new code has popped up and something needs to be repaired
Jan 26, 2013 | 2008 Mercury Milan
How much torque for head bolts on a 1994 Mercury Tracer 1.9?
step1:30-44ft-lbs,step2:loosen2 turns,step3:tighten 44ft-lbs,step4:tighten quarter turn from step3,step5:tighten another quarter turn.
Oct 17, 2009 | 1994 Mercury Tracer
Toys Logo
83 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
