Question about LG DLG5966G 7.3 cu. ft. Front Load Gas Dryer
Lg gas dryer new stats new coils and valve, ignitor glows but not hearing the snap of the coils and not getting gas
We have bypassed all stats to make sure its not a faulty stat new valve and coil kit
SOURCE: LG DRYER DLG2532W GAS
I had similar problem with my LG DLG2532W gas dryer:
1) Power on machine:
- Check Filter light comes on (LG says this is OK at start)
- Time lights have all dashes
- All Program cycle lights on (Air Dry up to cotton towels)
- This is all normal
2) Select program cycle (cotton towels for example)
- Check Filter light now goes off
- Time shows 58 minutes
- Dry Level, Temp Control, etc are set automatically
3) Push start (this is where the trouble begins)
- The "drying cycle" light starts blinking (good)
- The dryer starts turning (this looks good...but)
- The ignitor (heating coil that ignites the gas) never heats
- The gas never comes on (because ignitor not on)
- No heat ever is produced.
Net result is dryer looks normal and runs, but there is no heat.
There is no error code...nothing to tell you anything is wrong.
Your only recourse is to call a technician because the manuals do not explain anything in any detail.
Thank goodness for the internet. I just needed the one clue that there was a reset button on the thermostat. That fixed my problem. Here is some more detail in case someone else is having this problem:
There are apparently two thermostats in the dryer. They are on the exhast tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button. Before pushing the reset button PULL THE PLUG ON THE DRYER OR TURN OFF CURCUIT BREAKER. The reset switch is between two wire leads that go to the thermostat and you will probably shock yourself if you try to push the button with the power on. If you open up the right side access cover on the dryer, then you can see the exhast tube. It is about 5 inches in diameter and (looking thru the right side access port), it will be sloping up from left to right as it runs from the front of the dryer to the back. You can see another exhaust tube further away from the port and lower down, but the one you are looking for is closest to you and higher up. If you look back toward the front of the machine (left), you can see two wires hanging down from the opposite side of the exhaust tube. The wires run to the thermostat which you can also see on a bracket standing off the exhaust tube. In between the two wire leads that run to the thermostat is the reset button.
Bottom line....pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minuite operation if you can get to the right side access port.
If you cannot get to the right side access port, you can pull off the fronf of the dryer and get to it that way, but it is much harder. You start by popping the dryer top by pushing in a putty knife between the top cover and front cover about two inches away from the top left and right edges of the machine. This is tricky and takes some fidling. I just pryed mine open the first time, but now I see how it is supposed to be done. After popping the top, you can take off the front of the machine. There are two screws on the top and then two more on the bottn half of the door. You have to open the door to get these two screws out. There are some wires going to sensors and switches that have to be disconnected.
It is much easier to access the thermostat thru the right side access port.
Posted on Dec 01, 2007
MNTECH
  • 1543 Answers
SOURCE: LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
iwillfixforu
  • 619 Answers
SOURCE: Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Posted on Feb 01, 2010
heatman101
  • 43501 Answers
SOURCE: dryer will not start
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 11, 2010
  • 3074 Answers
SOURCE: I have an LG DLGX7188WM dryer that is not heating
http://www.applianceaid.com/gas_dryer.html#noheat
Posted on Jan 15, 2011
My matag gas dryer wont heat on any setting.
On a gas dryer the exhaust duct fuse mounted right next to the control T-stat kills the power to the gas assembly if the blower is restricted or worn out. A common problem with these dryers. If power is indeed getting to the gas assembly I would first check for continuity of the flame sensor switch mounted on the side of the burner area. It's job is to allow the ignitor to fire up when power is delivered to the gas assembly from the control t-stat on that blower housing. The flame sensor has to open when the ignitor reaches 1800f. At that point in time the ignitor becomes a thermocouple even with no power going to it it allows continuity through the coils so that they will get energy enough to yank open the gas valve. While the ignitor is glowing it is hogging all that power and the coils simply cannot pull the valve open. Sometimes a gas dryer will work a little then quit. that would be thos coils on the gas valve are weak. They get hot and fail. To get into the dryer you must first remove the door so that you can next get the front panel off. That will revieal the top holdown clips you remove. Then you can get the shroud off and remove the drum. I bet you would like a service manual for this beast:
Slope front Dryer Service Manual
Sep 29, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
Jun 17, 2011 | Kenmore Dryers
I see the ignitor element getting red but it will not light-off. I do not smell any gas, so I'm guessing it is not even coming out of the burner valve?? Would appreciate any help I can get. ...
Hello there and thank you for choosing fixya
If the glow coil does glow a very bright yellow white color, that solenoid is working. If the glow coil fails to light, replace that part only. <Use caution-glow coils are not cheap and break easily.>
If the coil glows but you do not hear the second click, which opens the second gas valve to allow the gas to exit to the burner, you will need to remove the gas valve assembly and replace both solenoids.
The solenoids are located on the top of the gas valve and are black plastic coated spool looking items. They are held in place by a retaining plate.
Carefully, remove and replace them with the new ones. <They only fit on the steel rod one way.> Replace the gas valve assembly, attach the quick disconnect wire clips and soap test the gasline nut you unconnected.
If the soap test proves there isn't any gas leaks, fire up the dryer and your done.
Mar 06, 2011 | Dryers
My LG Dryer DLG5988W wont always heat up. The
Dryer ignitors are not as tempermental as oven ignitors. If it glows, the problem is most likely is not the ignitor. One of the coils on the gas valve is the problem, but with LG, you have to get the entire gas valve, as the coils are not available as seperate parts. By the way, if you are testing the dryer with the front off, you have to make sure to cover the drum opening with something (like a piece of cardboard) so that you will maintain proper air flow for the burner.
Jan 25, 2010 | Dryers
I have a Roper Gas dryer and it works fine but the air never gets hot and it does not dry clother. It rotates fine but no heat. What do I do?
See if the ignitor is glowing. If it is you may have a weak ignitor or a bad coil on the valve. If it is not and you hear a snap when the dryer starts i could be the ignitor. If there is no snap then a thermostat or thermal fuse could be the problem. Eric
Jun 17, 2009 | Roper RGX5635E Dryer
GE gas dryer, no heat, new ignitor
Hi!! make sure that you have 120 volts going to the glow ignitor.the gas valve will not turn on the gas if the ignitoe wont glow..if it glows the check yout coil boosters they are round and are located by the gas valve.then if not you have a bad timer.they are usually round and are black..good luck..
Jan 03, 2009 | Dryers
Maytag Gas Dryer LDG7304AAE won't heat
Probably a high limit fuse. Check on the burner shroud for a 2 wire thermos. They should have little resistance. If so replace. If they are open, check for a restricted vent. Remove front panel and clean out area below filter.
Nov 12, 2007 | Dryers
LG DLG5966G 7.3 cu. ft. Front Load Gas Dryer Logo
11 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
