Question about LG Dishwashers
Leaking water FYI bottom
While running water leaks from bottom
SOURCE: leaking from the bottom a lot, immediately when I start the cycle
I found this post on another website. Hope it helps:
"Six torx screws securing the fine mesh filter just below the lower spray arm. Make sure they're all tight. Bit size is T 20 also, check for damage to the mesh screen. What happens when those screws are loose is water pressure seeps under and creates a tidal wave sort of effect by spraying water forward instead of thru spray arm...long shot, but I've seen it 50 times."
Posted on Oct 30, 2008
SOURCE: smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Posted on Mar 09, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Dishwasher is leaking and backing up with water
Sounds like the door gasket is leaking allowing water to come out
Posted on Apr 29, 2009
  • 20 Answers
SOURCE: my dishwasher is leaking on the sides of the door
Try cleaning the gasket. Around the bottom they will have a lot of food and soap build. It worked for me .Good luck
Posted on Sep 08, 2009
arikrom
  • 528 Answers
SOURCE: Our Kemore dishwasher is leaking water onto floor,
you just need to clean the pump area in the bottom of your unit :)
try to take spray arm out if you can and then open pump cover clean it good but watch for broken glass in it ...and thats it :)
Posted on Jan 01, 2010
Reliance 502
The problem is that your water heater is leaking and, depending upon its age, may be in need of replacement.
Dec 26, 2013 | Water Heaters
I top off my 1998 Nissan Altime's engine coolant evreyday. Also, the radiator fan stays on for appromiately 2 minutes after I shut the engine off. Is something wrong with the cooling system or the...
The fan running is normal. you need to find where the coolant is leaking. If there are no visable leaks. then suspect the radiator/reservoir cap.
Aug 14, 2011 | 1998 Nissan Altima
My Side by side frigidair refrigerator is leaking. The water is coming from the bottom of the refrigerator on the ice maker side. What could be causing this problem? FYI - the refrigerator works just fine...
Leaks are always some loose joints in the water drain or a possible pipe leak.
Now your observation to the leak is most important to the solution as a good view using a good lighting will allow you to get the first hand view to the issue.
I recommend that you get help to see the underside of the fridge using good lighting.
Once this is confirmed make sure if this is the drain defrosted tank or a flow line. If so drain and check, check if the defrost tray line is leaking from the water line. If so readjust or plug the leak.
Feb 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have water leaking under my dishwasher (probably right in the middle). I put a paper plate underneath to catch the water during the cycle. There seems to be some "soap scum" on the bottom where it is...
Hello there
Here is several ideas that will help you
also (fyi) type in search engine how things work and once it opens just enter dishwasher and it will bring you to the dishwasher section ok?
here it is
Dishwasher is leaking water
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Water or soap leaks around the door
  • Make certain that your detergent is intended for dishwashers. Do not use liquid dish soap.
  • Inspect the door seal gasket
  • Check the door latch
  • Inspect the door hinges
  • Inspect the spray arms for damage
Water drains through the air gap into the sink
Sep 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Leaking water from the bottom, checked all connections and no leak from connections. Also making noise when running.
Take front of washer .. get light and look for leak and listen to find out where noise is comeing from
Nov 18, 2006 | Amana LWA40A
Dishwashers Logo
12 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
