Question about Sony Alpha DSLR-A200 Digital Camera
What causes noise and vibration in the lens whe. turned on axa100
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sony Expert
  • 322 Answers
It's almost certain that some part of the lens or the supporting framework are faulty. You can try troubleshooting the device with the user manual, but you will probably need to have it repaired. Try checking out the user manual to be sure:
Sony DSLR A200 manual
Posted on Jan 18, 2015
I have Sony T-200 for more than 2yrs. It has been working alright. Now when it is switched on it vibrates and the picture you get is out of focus?There is no vibration when viewing pictures.
hi, your camera has IS unit get defective cause vibrate noise. and out of focus. It will require realignment or lens unit assemble or replacement of the lens unit. your local repair shop would charge around $65 to 135 depend on what they really want to charge. Good luck with you and best regard!
May 22, 2011 | Sony Cybershot DSC-T200 Digital Camera
My olympus fe was dropped when the lens was closed, and everytime i turn it on the lens gets stuck out and makes a vibrating noise, than stops. sometimes it'll show me my pictures that i have on the camera...
Since a replacement is available for £46 on Amazon, and the repair charge would probably be at least that if not more, i should just replace it. And this time, don't drop it.
Jun 10, 2017 | Olympus FE-220 Digital Camera
When I use camera in vr option I hear when I shooting in the end of shooting a litle clikc in camera and the screen pictures a little jumping on the screener.is it a normal or not. When I switch off vr...
The Vibration reduction system does move components inside the lens. If it makes a lot of noise you are better off turning it off and using a tripod. The VR system will move lens components to counteract your motion. The steadier you hold it (camera and lens) the less noise. On small Coolpix cameras the sensor is moved to counteract the vibration while it is hand held.
Oct 01, 2017 | Nikon 105mm f/2.8G ED-IF AF-S VR...
Steering wheel vibration whe I rotate it??????
The vibration and rubbing may be separate issues. There could be many causes for vibration, ranging from low fluid, sticky rack valves, etc., to the tires simply grapping and releasing on the pavement. If it only does it under heavy use, such as when standing still and turning alot, then I suggest not doing that. It is hard on a car to turn the steering wheel when the car is not moving.
May 21, 2010 | 2008 Hyundai Elantra
Cyber-shot DSC-T70 Digital Camera: My Sony Cybershot dsct70 touch screen vibrates whe...
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
May 16, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
When the light outside on the left door is on
If it is not affecting operation (cooling) then it is probably annoying vibration. Nothing to worry about.
Mar 25, 2010 | Hotpoint HSS25GFP Side by Side...
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Not working with Sony Alpha 100
well after a week in the shop it came back working. the guy at the shop could only tell me that the repair people had fixed a problem in the auto focus (he had no other information). So the solution here is going to a place to repair your lens. if someone finds the cause of this problem it would be great
Feb 25, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sony Alpha DSLR-A200 Digital Camera Logo
83 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
