Question about Saeco Coffee Makers & Espresso Machines
Lubricating grease coffee machine
Where to buy the grease
2 Suggested Answers
SOURCE: Lubricant for bread maker pan mixer shaft
I just cleaned the shaft and put on Silicon. It seems to be working at top speed now. I almost threw the machine away, but itt makes wonderful bread.
Posted on Oct 01, 2009
I have Phillips Saeco xsmall machine. Coffee was ok at first. Then it started making VERY weak coffee.
1-just descaled the machine(see manual,use citric acid, NEVER vinegar)
2-The reason could be the piston is not moving all the way down. Try pushing it down with your thumb and you will see if this is the problem or not. To repair you have to lubricate piston's shaft really well (with food-grade silicone grease or vaseline) so it moves up and down easily. You can try using an artist's brush to reach the shaft, but if it doesn't work you will have to disassemble the mechanism. If the piston won't go all the way down, not enough coffee will fit in the cylinder and the pill will be soft. Also lots of coffee will end up freely floating inside your machine.
Nov 11, 2017 | Saeco Coffee Makers & Espresso Machines
What is the best lubricant to use on my dewalt hammer drills please
It depends to where you want to apply your lubricant.
If you want to lubricate the chuck with the sds drill bit you simply add some cheap grease on the drill bit and the drill bit will slide easily on the chuck. On the other hand if you want to lubricate the sds drill machine then there is a special type super grease that you can buy from Dewalt in order to do so. Also since in order the super grease to be needed this means that you have used the drill a lot then also is needed to change o-rings, brushes and so on. So usually you have to ask for a service center to do it since they know how to do it properly and using the right kit.
Oct 18, 2014 | Dewalt Drills
I need descaling tablets and machine lubricant grease. How can I purchase these items?
Amazon.com sells the descaling tablets as well as the cleaning tablets, Miele brand. Search on "Miele tablets" for example. Third party (non Miele) tablets are available but you might not want to risk using those in your $3K machine. If you search on "food grade grease" you can find a small tube of it that sells for about $8.
Aug 10, 2011 | Miele CVA615 Espresso Machine
Brewunit blocked
Have you ever cleaned and lubricated the brew group?
You remove the tray and set it aside - then push to the right the plastic bar that says "press" and pull out the brew group. It comes out as a complete unit. You can rinse it under the sink - turn it over and rinse off the filter disk and rinse off any coffee grinds that may be stuck all over in the mechanism. Do not use detergent, do not put in the dishwasher. Just rinse it off really well.
The mechanism should be lubricated with food safe lubricant after about 500 coffees. There are two sets of tracks that are the main thing to lubricate. You can get the food safe silicon grease at any of the espresso shops like wholelattelove or seatle coffee gear etc. etc.
If the brew group moves freely after you have cleaned it, you need to make sure it is the home position - the round well with the black plastic shower screen at the bottom should be centered under the funnel that the coffee grinds drop into - and on the front face, below the "press" bar there is a round bushing with two arrows that show be pointing at each other showing that it is lined up in home position ready to be reinserted into the machine.
Oct 10, 2010 | Gaggia Titanium Espresso Machine
Saeco Italia Digital Barista Fully Automatic Coffee Machine: I've had an Italia Digital for ~3 yrs. I keep it w...
Could be the burrs on the grinder are dull, instead of nice ground coffee it is producing crushed coffee.
May 18, 2010 | Starbucks Saeco Italia Digital Barista...
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Any advice on lubricating the Saeco Giro brew group? I have the lube, and assume that I just dab it on the various joints. Anything to avoid?
most importanly grease the spindle that moves the botton pistion up and down bottom center, sould move freely .then some on the side tracks
Nov 30, 2009 | Saeco Odea Giro Espresso Maker -...
Jan 05, 2009 | Kitchen Appliances - Others
Brewunit block
kristijordan,
I had this error message on my machine and was able to take care of it by lubricating the brew unit with silicone. I small tube of silicone grease should have come with your machine. If not I found silicone grease at Aco Hardware (not in a tube) and applied it using a toothpick. Machine has been working great since.
Winesnob
Sep 10, 2007 | Miele CVA615 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
