Question about GE Profile JP930 Electric Cooktop
Glass top for ge range glass top only
Where can i find just the glass top for my ge range no assembly just glass top
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
Need to clean contacts on control knobs under glass cooktop on ge jgp640 downdraft top. Ignitors wont stop clicking. Is the top glued to the chassis
Sorry to read about your problem, I hope this helps you out.
their is no cleaning of contacts, they are sealed units..have to replace the switch,
you have to remove the entire range from the counter top..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 16, 2010 | GE Monogram ZEU36 Electric Cooktop
My ceramic cooktop has cracked. Can I just order
You can get the main glass top, the part number is WB62T10525 and it runs just under $300.00, it is shown here as 51. It does take a bit of dis assembly to install it.
May 05, 2010 | GE Cooktops
My glass top has a broken in the corner on my jgp932 cooktop range can i just get the glass top replaced and can i do it myself
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Apr 23, 2010 | GE 30 in. Profile JGP932 Gas Cooktop
I have kenmore ceramic top range model number 79096011407, the glass top is cracked and I want to replace it but don't know how it comes off the manual is lost. There are three screws above where the oven...
are u sure u want to replace the ceramic glass top,much beter to check the price of the unit, coz it is very expensive almost halt the price of the new one...dont try to replace it by ur self coz the glass cover is no waranty if u broke or wrong intallation,u waste ur money if hapen that,much beter to canvas first & call an expert tecnician to do it.
Sep 08, 2009 | Cooktops
Cooktop glass broken - need a replacement - where can I find it?
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
Dec 23, 2008 | GE Profile JP930 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE Profile JP930 Electric Cooktop Logo
67 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
