Question about Denon AVR 2808Ci Receiver
I have a Denon AVR-2808 CI receiver. It is connected to my Samsung TV, Sony DVD player and AT&T cable box. I have AT&T Uverse. I am not able to get any picture on my TV when I turn my cable bo
I have a Denon AVR-2808 CI receiver. It is connected to my Samsung TV, Sony DVD player and AT&T cable box. I have AT&T Uverse. I am not able to get any picture on my TV when I turn my cable box on. All other components connected to the Denon work just fine, DVD works (I can get the picture), radio works, but just not the cable. I can see my cable if I disconnect it from the Denon and connect it directly to the TV. HELP? Also, Denon does not have a preset code for AT&T cable. Could this be the problem? I also tried the Learning function as suggested in the manual, but that did not work either. Please help!
suffolkpo
  • 6 Answers
SOURCE: Denon AVR 1803
Hello, I think that you've got a problem in the relay circutry or a logic problem. tell ya what I ve got the service manual and schematic for the reciever. the engineers at denon where ahead of there time when this company started. they designed the equipment around what they wanted the specs to be for signal to noise and discrete audio channels. each of the sound channels from the component and composite inputs is given its own bus and amplifier channels. these paths are also common to the reciever/tuner outputs. one question though you mentioned that the composite/component video paths are not switching from the input to the output youve designated, and that the monitor checks good. do you have another video source,either digital or analog that you can input throgh another channel to see if it is infact a switching problem. try that and let me know. I can give you help with the switching circutry form the schematic if need be. believe me I know It took me about a week to track down the service schematic for this unit. Denon doesn't like giving out info unless you are an authorized repair center.
Posted on Jan 03, 2008
  • 119 Answers
SOURCE: hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Posted on Feb 25, 2009
SOURCE: No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Posted on Apr 15, 2009
  • 119 Answers
SOURCE: Describe your Denon AVR-3805 7.1 Channels RecI
There is a button on the front of the unit under Input its a mode button press this button to select auto that should give you sound
Posted on Aug 02, 2009
smarthome2
  • 1114 Answers
SOURCE: no picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Posted on Feb 28, 2010
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
I am not able to get audio through my HDMI cables.
It's a monitor - no audio source capabilities.
Get TV-related audio from its original source, not the TV or monitor. TV's and monitors are NOT hi-end audio sources.
Cable box, DVD, BD, games: these are potential hi-fi digital audio sources.
May 25, 2010 | Denon AVR-3300 Receiver
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
AVR 2808 CI remote does not recognize back speakers.
perhaps that's why it was returned...Take it back for a replacement.
Apr 01, 2009 | Denon AVR 2808Ci Receiver
Hi denon to cable box to samsung lcd
Feb 25, 2009 | Denon AVR-5803 Receiver
Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Nov 05, 2008 | Denon AVR-1905 Receiver
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
How to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Jun 21, 2007 | Denon AVR-886 Receiver
Denon AVR 2808Ci Receiver Logo
57 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
