Question about Panasonic PT-61DLX76 Television
Replaced lamp on Panasonic PT-61DLX76 in Dec '13, blew out in Feb '14, replaced lamp again, blew out in a few hours
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Posted on Jun 02, 2009
  • 2336 Answers
SOURCE: how to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Posted on Jul 25, 2009
  • 1738 Answers
SOURCE: can i replace the lamp my self and order the lamp
Yes. The companies actually tell you that the lamp is customer servicable.
Posted on Oct 11, 2009
Testimonial: "thank you thats what i wanted to hear"
  • 32 Answers
SOURCE: How do I reset the Panasonic PT-40LC12 projection
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Posted on Jan 20, 2010
Testimonial: "Thank you so much for your help. Worked like a charm!"
I need to reset the lamp timer on a PT-61DLX76
I'm glad to provide the instructions to reset the Lamp Time of the TV. Once you replace the lamp of the TV, please follow the below steps to reset the Lamp time:
With the TV on, hold VOL [-] on the TV and [0] on the remote until a message appears on the screen.
Thanks for understanding. Please let me know if you require any additional help.
Jun 07, 2011 | Panasonic Televison & Video
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
The picture on my 13 yr old panasonic PT-51G44 ia darkening. Is this fixable or do I need a new tv?
Yes,the tv is fixable.When was the tv projection lamp been inside this tv was replaced in this tv,when was it the last time the bulb was replaced?The last time the probjection lamp was replaced about 1 1/2 or 2 years ago?The tv on an used at leat 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
How reset the lamp in panasonic tv PT-50LC-14 ?
While holding Volume Down button on TV Front and press and hold Play/ PIP button on tv Remote at same time for 6 or more seconds to reset lamp hours.
TV will show lamp reset message on screen.
Thanks.
May 02, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Need projection lamp for pt-61dlx76
the original panasonic part # is TY-LA2006 available from panasonic dealer near you. Also jobber lamp may be install in the old lamp box, for a fraction of the price but is it the same quality?
Apr 27, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
How to reset lamp timer on panasonic PT-61dlx76
If the above do not work, after message to reset goes away, press and hold the volume down button on TV and then the zero button on remote.
Dec 23, 2009 | Panasonic PT-61DLX76 Television
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
There is no picture or sound and the lamp light is red.
Most likely the lamp is burned out buy you a new one and replace it. It is consumer replacable.
Aug 06, 2009 | Panasonic PT-61DLX76 Television
Lamp
you have a problem with the lamp on the tv
is easy to replace only take cover off two phillips screws and inside two more screws
take off lamp and buy new one
Jul 29, 2009 | Panasonic PT-61DLX76 Television
Panasonic PT-61DLX76 Television Logo
15 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
