Question about Minolta Optics
Rubber coating become sticky to clean - Minolta Optics
4 Suggested Answers
Tildenator00
  • 47 Answers
SOURCE: rubber coating has become sticky
try keeping it in a cooler place and the rubber should harden
however I would first check the box to see if it is supposed to be tacky which means it is supposed to be that way
Posted on Jan 26, 2010
Testimonial: "Thank you. As binoculars have been kept in their box in a drawer in a warm room for years your suggestion of keeping them cooler may well work. "
Obertelli
  • 3006 Answers
SOURCE: i own a leica 8x42 ultravid,the rubber coating has
If it is salt, then it's water soluble so just use a damp cloth.
Posted on Feb 19, 2010
SOURCE: rubber coating on my tasco exp scope has become
Talcum powder solution does not work, it will become gooey again. I have two of the scopes same problem on both. The coating can be removed with WD-40. Do not spray directly on to the scope. Spray a paper towel and gently wipe the goo from the scope. It takes a lot of towels but the end result is a scope the looks the same but with out the gooey coating.
The 3-9 scope I have recently stopped focusing at greater than 80 yards and I'm sending it back for repairs. It will be interesting to see how that goes.
I have begun switching to Leupold scopes for all of my rifles and pistols. Really too bad as I thought the Tasco EXP was great when it first arrived. I just don't have the time to fool with a product that should work.
Posted on May 01, 2010
Mouse Body Is Sticky How Do I Clean It?
I had the same issue and using clorox wipes only made it worse. I eventually used Lacquer Thinner, which is usually a mixture of solvents able to dissolve a number of different resins or plastics. It can be purchased at most home improvement or hardware stores. It worked perfectly.
It is a bit of a messy process and there are fumes. I wore rubber gloves and did it in my garage using several paper towels. I also recommend applying scotch tape to the edges of the non-rubber areas to protect the finish. Also avoid getting it on the bottom of the mouse.
Jul 26, 2012 | Microsoft Wireless IntelliMouse Explorer
What is the finish on the black matt speakers
Unscrew the front of the speaker, hold the casing over a baking tray, repeatedly wash and work the thinners into the casing with a clean paint brush.This will gradually remove the sticky coating leaving the surface smooth and clean. Don't forget to wear rubber gloves.
Apr 27, 2012 | KEF Audio KHT 2005.2 System
Sticky
Possible that the rubber has vulcanized due to exposure to heat, try and use a external coat or rubber cover or you will need to replace the handle.
Mar 14, 2012 | Cars & Trucks
My Tivoli Pal radio casing has a sticky feel on it, everywhere...how does one clean this or make it non - sticky
Just cleaned mine this morning because it was so ridiculously sticky and dirty with great success with nail polish remover and cotton pads. Read this solution posted elsewhere but was worried about ruining the finish, and there are warnings on the bottle about not using it on plastics......but tried a bit on the back. Went very well and with a load of pads and alot of scrubbing, it came completely clean! No sticky residue left, no discolouration. Looks brand new!
Feb 23, 2011 | Tivoli (PAL) AM/FM Radio
Rubber coating has become sticky
Jan 26, 2010 | Optics
Rubber coating on my tasco exp scope has become sticky and seems to smear black when rubbed. any suggestions?
Dust with fine Talcum powder, ie baby powder. Distrubute powder over rubber and it will harden up the rubber, let sit and gently rub in. After a couple of minutes dust off excess. repeat if required.
Sep 13, 2009 | Tasco EXP-1042 (10x42mm) WP
Praktica sport zoom 7-21x25
I have the same problem with my Nikon N65 film SLR and I bought a vintage Super 8 movie camera where the rubber had turned to the consistency of gum on a side-walk on a hot summer day. On the a camera I carefully rubbed on a coat of talcum (which probably isn't the best thing to use on a camera but I was careful and it isn't something I do every day). I then took a small square I cut from an old terry towel and used friction and elbow grease to rub off the top layer of the rubber. I then took another square of the towel and dipped it in hot soapy water, squeezed out the excess and washed all that remained. I then took a small water-colour brushed (after I dried the surface of course), and dusted the surface of the rubber with talcum and let it sit overnight. This seemed to stop the derioration and clear off what had built up. The next day I took a very dry damp towell (if that makes sense) and wiped off the surface. It pretty much took care of that problem. That was the Nikon, it was only in the beginning stages, the Super 8 camera which had apparently hadn't been out of the case in 20 years. The Super 8 was so bad that I don't even know what had deteriorated, probably a rubber eye piece, that one was time consuming but basically I put the powder on carefully and just wiped big clumps off the metal eye piece. The powder just served to make it easy to clean up and kept it from turning into a 3 stooges farce with one thing sticking to the other and so on. Well, I hope this helps, I don't know why it works, maybe there's a chemist out there that can explain it to me. Good luck!!
Jun 29, 2008 | Praktica Roof Binocular
How do I clean the Fuser Roller
Metho.
No use inkjet stuff in laser machines.
May need to replace Fuser.
Dec 25, 2007 | IBM Infoprint 8 Laser Printer
Rubber coating breaking down
Try it with rubbing alcohol first - just keep it away from the optics, and you may get lucky. The only thing that ever seems to work with these is an abrasive cream cleaner (jif/cif or similar) - you just have to use lots of cream and be careful not to polish the optics - unfortunately the stickiness will come back quicker than before though. I haven't tried myself, but i have heard that once you have carried out the cream cleaner routine, you can paint the unit - ask your hardware shop what sort of rubbery paints they have - ideally oil based and not acrylic. It wont last as long as the original finish or like quite as good, but it should stop the stickiness for a while at least. Try and keep your binoculars out of the sun - most of the stickiness is either caused by that, or contact with a damaging chemical such as most insect repellents, or petroleum products. Hope this helps :)
Aug 08, 2006 | Sigma Elite 8x22 Binocular
Optics Logo
51 people viewed this question
Top Minolta Optics Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Minolta Optic Expert? Answer questions, earn points and help others
