Remote control manual
My Samsung TV has picture in a Picture. My new remote from the cable company (ServiceElectric) model - 2025B1-B1 has the PIP button but does not work the function. Can It be programmed to do it ?
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Posted on Jan 15, 2008
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
Does hisense smart tv have pip mode?
Do you have an original remote control for that TV? If so, is there any marking on that remote for PIP (or picture in picture)?
May 11, 2017 | Hisense Televison & Video
What are instructions for Split-screen TV? Used before, forgot.
You are referring to a picture-in-picture function on hour TV. It is usually done by a button on your remote control marked PIP - picture-in-picture. If your TV doesn't have this function you can get it by using your SET-TOP BOX, which supplied by your TV cable company. All modern remote controls fro those boxes have that ability. In this case you will be able to watch two channels at the same time, switching them around and control them the way you want.
Nov 09, 2014 | Protron Televison & Video
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
I want to figure out how to get the picture in picture and the half and half screen on my tv. It's been done before. It's a Samsung PLasma. What do I push on my remote?
If there is no PIP button on the remote then the PIP functions was that f a cable box. If you are connected to a cable box you are only supplying one channel at a time and you will see only one image.
Sep 11, 2009 | Samsung 50" 1080p Wireless Flat-Panel...
Picture-In-Picture does not work (32" LG LCD)
my friend told me that if Tv is purchased from Canada will not work in Saudi Arabia but why?
Mar 18, 2009 | LG 32LG30 32 in. LCD HDTV
TRINITRON XBR/ADVANCED 2 TUNER PIP Model KV32XBR45 Manufactured 1995
WELL I need some more information so I be able to assist you, first , it could be that the REMOTE CONTROL is not that came with the TV originally , and since all SONY remote control have the same basic codes ,it could be that the remote doesnt have this specific feature. I did some research base on the model of this TV , the original remote control model num. is RM-Y127 and
not RM-Y153 , maybe thats why it doesnt have the PIP feature. hope this info been helpful
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Turning OFF picture in picture!
I have an old Sony Trinitron; had the same problem... somehow turned on the pip while moving the television off its stand. I have neither the remote nor the manual.
Does your tv have a 'demo' button on the front? Mine does; when I pressed it, the pip disappeared!
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
