Question about Champion G5NG853S Household Juice Extractor
AMy old champion juicer would only hum when I turned it on this morning, the spindle wouldn't spin. Any ideas?
  • 69 Answers
SOURCE: cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Posted on Feb 07, 2009
  • 69 Answers
SOURCE: Champion G5NG853S Household Juice Extractor
Juicer has to be attached, little magnet on the bottom.
Posted on Mar 01, 2009
  • 69 Answers
SOURCE: Champion juicer don't work
You have to have the juicer attached, there is a little magnet that allows the machine to turn on.
  • 3 Answers
SOURCE: My champion juicer just stopped working. Makes no
Championjuicer.com sells replacement switches. Order the oil seal and o-ring too to save on shipping. Newer models have a safety cut off that does not allow the juicer to turn on unless all parts are properly positioned.
Posted on Dec 02, 2010
SOURCE: Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
Posted on Apr 18, 2011
Champion juicer model G5-NG-853S stopped working. Do you have a repair facility somewhere in central Florida? Are there any warranties for this juicer?
FIXYA is not a manufacturer or seller of juicers.
You need to search elsewhere for assistance with repair or warranty replacement.
Mar 28, 2018 | Champion Juicers
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
Jun 13, 2014 | Champion G5NG853S Household Juice...
I installed a new hub on a Champion Juicer, reconnecting the wires that are attached to the magnet; when I turned it on there were lots of sparks. Any ideas to what could be wrong?
I have had good experience with their technical support.
Corporate Headquarters:
PLASTAKET MFG. CO., INC. / Champion Juicer
6220 E. Highway 12
Lodi CA, 95240
USA
Tel: 866-935-8423 / 209-369-2154
Fax: Fax Number
E-mail Contacts:
Business Relations - sales@championjuicer.com
Wholesale Inquiries - doug@championjuicer.com
Nov 17, 2011 | Champion G5NG853S Household Juice...
We just got a 2nd hand juicer CHAMPION model G5-NG-853S. Where can I find a manual for it.
The CHAMPION juicer manual is online at: http://www.discountjuicers.org/manuals/champion.pdf
If your juicer needs parts or maintenance, the phone support is easy to work with - call them directly at:
(209) 369-2154
Jul 26, 2011 | Champion G5NG853S Household Juice...
My champion juicer just stopped working. Makes no sound at all when I flip the switch. Any ideas?
Oct 25, 2010 | Champion G5NG853S Household Juice...
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
Motor won't work on Champion unless I press on part
it probably has developed a loos connection inside. Pressing on that part reconnects the loose connecion inside the machine. If you are someone with a good mechanical aptittude, you may open it and somehow make a hood connection again. The problem should be obvious, and straight forward to fix.
Jun 27, 2009 | Champion G5-PG-710 650 Watts Juicer
May 23, 2008 | Champion 2000+ Household Juice Extractor
Jan 09, 2008 | Champion G5NG853S Household Juice...
Champion Juicer stopped working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Champion G5NG853S Household Juice Extractor Logo
56 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
