Question about Police Detroit, Mi Police-1999 Ford Crown Vic
Fuse box digram
Cruise control
2001 Pontiac aztek cruise control stopped working along with the ABS
Cruise control fuse # 31 10amp located in the under hood fuse / relay box an HZDFL fuse # 40 15amp located in the center console fuse box . If you pull the plastic side panel off of the right side of the console there is a fuse box inside . If the fuse are good the control module could be bad . Could also be turned off because the ABS has a problem .
DTC P1554 - do you know what a diagnostic trouble code is ?
The powertrain control module (PCM) has the ability to inhibit cruise control operation if conditions exist that would make cruise operation undesirable. The following conditions may inhibit cruise control operation:
• The engine speed is too high or too low.
• The vehicle speed is too high or too low.
• The traction control has been active for longer than 1 second.
• The vehicle acceleration or deceleration rate is too high
If the ABS light is on ,there are DTC'S stored in the system . Your best bet , take it to a GM dealer or someother qualified repair shop.
Mar 03, 2017 | 2001 Pontiac Aztek
Fuse location for cruise control
Since there is no throttle cable, there is no "cruise control" fuse. The fuses used are #7, 9,and 13 in the under hood fuse/relay box and #18 in the under dash fuse/relay box. The most common failure is a bad brake pedal switch. Does the cruise control main switch "on" light work when the switch is pressed? The gauge control module (instrument panel) and the PCM control the cruise control.
Apr 05, 2015 | 2006 Honda Ridgeline
Where is the cruise control fuse
The power for the cruise control comes through fuse #14 in the fuse box. From there it goes to the Cruise Control Switch. However, the Cruise Control Module is above the Fuse/Relay box, behind the dash board. Good-Day!
Jul 26, 2014 | 1997 Volkswagen Jetta
I have a 1994 mercury grand marquis. The cruise control stopped working today so I believe a fuse blew out. Can you tell me what is the number slot in the fuse box that is for cruise control? Thank you
Hi Debbie,
First I think it should be said that whatever is wrong with your cruise control it is definitely NOT caused by a fuse. Fuses do not cause electrical circuits to fail. Failing electrical circuits case fuses to blow.
With that said, there are 2 fuses that affect your cruise control operation:
Fuse #6 (10 Amp) and Fuse #7 (15 Amp), both of which are located in the instrument panel fuse block. Fuse #6 is the power feed to the cruise control servo and Fuse #7 is the brake lamp fuse, which provides power to let the cruise control servo know when you have applied the brake.
Oct 17, 2011 | 1994 Mercury Grand Marquis
Cruise control problem
There are 3 places on the Rav4 where fuses can be located and checked. for the cuise control.
The back of the cruise control stacking switch has been know to fail (fall apart) and Toyota issued a TSB with replacement switch.
if it is the fuses then they most likely are related to cruise control system: Stop, Dome, Gauge and Igniton
The interior fuse box
The main engine fuse box (by brake fluid)
Cruise control ECU is under the glovebox.
Cruise control actuator is under hood (by driver side brake fluid/booster)Throttle position sensor (to detect if your foot is on gas pedal)
Cruise control switch on the clutch pedal too (if you have 5spd manual)
Brake lights are the deactivate signal for the cruise control
Aug 13, 2009 | 1998 Toyota RAV4
2003 Mazda tribute cruise control stopped working
the problem is more likely the cruise cable its self. if you pull the engine cover you will probably fine the cable has fallen off at the throttle body. the only way to fix this problem is to go to the dealer and buy a new cable.
Jul 02, 2009 | 2003 Mazda Tribute
Cruise control does not function
cruise on a ford escort?? not fitted to europeon model thats for sure.All fuses are in the fuse box above left knee ,unhook the fuse box and let it drop to get at relays.
Feb 18, 2009 | 1997 Ford Escort
Cruise control
Under the hood is a relay box and after you take the lid off of this relay box it will tell you inside the lid which relay is for what thanks jerry holler if you need more.
Feb 07, 2009 | 2000 Ford Focus
Dodge Dynasty Cruise Control problem
THE 2amp FUSE IS IN THE GLOVE BOX FUSE PANEL.
Dec 29, 2008 | 1993 Dodge Dynasty
Police Detroit, Mi Police-1999 Ford Crown Vic Logo
12 people viewed this question
Top Police Toys Experts
Lawrence Oravetz
Vernon Taylor
Are you a Police Toy Expert? Answer questions, earn points and help others
