Question about Hoover Washing Machines
Fitting Hoover hnl842 door seal
How to fit replacement door seal
SOURCE: fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Posted on Feb 07, 2007
TampaNative
  • 778 Answers
SOURCE: FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Posted on Mar 29, 2008
MsMitch
  • 41 Answers
SOURCE: fitting washing machine boot gasket/door seal
If you don't already have the part go to an appliance store to order it and ask for the instructions.
Posted on May 23, 2008
  • 1462 Answers
SOURCE: fitting door seal
this is general for fittying door boots.
on cabinet, door boot is usuallyn held by a wire ring tensioned by a small spring. prise it out with a screwdriver.
on tub, door boot is held usually by a giant hose clip for want of a better description. unscrew the tensioning screw and remove.
door boot will then pull off - just pull it off in one place then go round the circle.
to refit.
lubricate the groove in the door boot that fits on the tub with washing up liquid. insert groove on tub at any convenient place and force into position by running thumbs round it in opposite directions. this is a knack i have to say.
when on, replace the giant hose clip and tighten.
slip the outer part of the door boot on the cabinet - this is usually easy. replace the holding clip.
put onto rinse cycle to test for leaks
good luck
Posted on Jun 24, 2008
  • 1294 Answers
SOURCE: fitting of door seal on zanussi electrolux washing
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Posted on Mar 12, 2009
Hoover u 5280 spits out dust
replace the bag
check that the bag is correct and correctly installed
if bagless check for seals around the dust container fitting check for cracks in the bagless enter point
take it to a vacuum cleaner repair shop for an inspection and quote
Sep 16, 2016 | Hoover Vacuums
The fill pipe has come loose from the outer drum on a hoover WMH148DF Washing machine how di get at it?.
Firstly,make sure machine is turned off at the wall.the easiest way is,by carefully putting a small flat blade screwdriver under the plastic ring that holds the door seal to the case of the machine, gently pry the ring off the machine. Now peel the door gasket away from the shell and fold it inwards into the drum.
You may need a torch now. Pushing the gasket back look into the left, front of the machine and on the front of the tub you'll see the fill hose that comes from the soap dispenser. Check that the hose has not come loose, or possibly rubbed a hole in it off the tub. You can re-seal it by just applying standard silicone/mastic.Re-fit in reverse, but firstly open the door gasket clip completely to making fitting possible. Once you've fitted it just give it a good squeeze.
Nov 23, 2014 | Hoover Washing Machines
How do you attach the upholstery tube to the main unit? thanks!
The larger fitting slides into the front of the dirty water tank. Remove the lid and either remove the duct, or lift it and tilt it forward on more recent models. The hose fitting goes in with the opening up, and the "V" shaped end down. After replacing the lid, push the round connector down onto it's fitting under the trap door on top of the nozzle, being sure it is fully snapped in place.
Feb 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Need to replace the door gasket. Can this be done with the door on?
Door on is the preferred method for me. Once you take it off and place it on the floor you can break the handle. (must remove the handle if you remove the door or place it on blocks of wood. (IF you remove it)
It is a matter of loosening the screws removing the old door seal and fitting the new door seal in place.
(Tighten the seal mounting / hold down screws when your done fitting the new seal.)
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Washing Machines
Replaced door seal now door is difficult to close.
Sometimes, it is hard to close door after fitting a new seal.
Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
Try smearing the door glass with washing up liquid, this can help to close the door more easily
Please rate my solution.
Thankyou.
Feb 13, 2010 | Ariston Technologies Washing Machines
Hoover washing machine door handle
if any one is stuck fitting a door handle to a hoover washing machine HNL 6146 nextra series then please email me johndgill49@hotmail.com
Aug 29, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
