Question about Office Depot Ativa 1250 (MicroCut) Shredder
Auto shutover doesn't work
After feeding the paper, the shredder doesn't shut off. I have to switch it off
3 Suggested Answers
SOURCE: Shredder runs in reverse, but will not feed in auto.
my Ativa DQ61Mn will not power up. I check other equipment which is connected to the same power source and they power up. Is there a reset button somewhere?
Posted on Jul 02, 2008
SOURCE: Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Posted on Nov 10, 2009
Does not auto shut-off anymore?
Automatic feed switch jamed with paper. reverse and forward several times may help. Otherwise turn it over and pull paper out of the bottoms to clear the switch jam.
Apr 06, 2015 | Cross Executive EPS-1501X Shredder
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
I have an Ativa AT120DC. It won't operate
I have an Ativa AT120DC Shredder. When it is switched to auto there is dim green light and it doesn't start. If I feed paper in it makes no difference. For some time it always started up when you switched it to auto and didn't wait for paper to be fed through. If you remove the basket the Door Open light comes on. can you help?
Mar 18, 2010 | Office Equipment & Supplies
The Auto-On switch does not work. I have to manually turn the shredder on and then feed paper into the slot. It feeds and shreds the paper just fine, but I have to manually turn it off to stop it. All of...
There must be an auto-on/off sensor in the middle of the paper entrance slot - either mechanical or optical.It needs to be cleaned from any obstructions like paper chads or paper dust.It this doesn't help,the sensor maybe defective and it needs to be replaced.
Oct 02, 2009 | Fellowes Powershred SB-87Cs Shredder
Office max paper shredder switch
If you are referring to the paper feed sensor switch in the paper throat it sounds like the pc board or switch itself may be bad. I could troubleshoot a little better if I actually had you on the phone. A Customer Service Rep can help you at 1-800-945-4545.
Apr 26, 2008 | Shredder SH2006PB
Auto Shut off doesn't work anymore
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Either of these should be located in the center of the paper throat.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Dec 20, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Shredder runs only forward
Oct 11, 2007 | Aurora Global AS1502X Shredder
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Office Depot Ativa 1250 (MicroCut) Shredder Logo
57 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
