I have a problem with a westpoint eolia model MSC 36, afther 5 mins running time it stops and a green led auto is displayed, what did this error means, thanks a lot!! b,tw, it has two pc. boards one for in and outdoor.
SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Posted on Nov 17, 2008
RescueTech
  • 145 Answers
SOURCE: Error U3
That's a "Low Pressure" fault and it's possible you may only need to reset the mode. This question is posted under DD603 but a U3 code is usually associated with the 602 models. I am including an instruction for you on how to check the setting. Start with that first, it is easy to do.
Posted on Dec 14, 2008
  • 18 Answers
SOURCE: Epson Stylus CX3600 error
remove the cartridges then, the press and hold all the available buttons on your printer where it could cause a machine resetting...
you could also remove the cartridges then wipe the circuitry of the cartridge... (the gold-like connector)
then turn off your printer without putting back the cartridges... (leave it turned off for 5 minuets)
turn your printer on then it should be ok
(post back if it doesn't work)
Posted on Jul 07, 2009
  • 6 Answers
SOURCE: After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Posted on Jul 29, 2009
cene765
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
Westpoint Eolia split system air condition would not power on. Panel reads F8. What does this mean? What should I do
Pls. let me know power consumption of split cooling system for home used prouducts . thanks
Nov 01, 2010 | Heating & Cooling
I have a canon pixma mp160 and the ink absorber is full. It is showing an error 8 on the lcd display. how do i fix it?
follow this steps to fix this error.
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2.When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3.When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4.When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
5.Turn off the printer.( it must be turn off) then turn it on again.
Sep 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Displaying E15 in M160 all in one
Check your ink cartridges:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out andthe LED Display should go blank. If the lights do not go out, thenrepeat step 3 until they do. It may be necessary to increase ordecrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Originally posted by tryit
Dec 04, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error E 4, 2 canon pixma mp 160
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
Service mode operation procedures -
the LED lights alternately in orange and green, starting with orange.)
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
Jun 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Sharp AL-1655CS ERROR MESSAGE
The [H4-00] system error popped up when the power went out of the house. I called Sharp Tech Support (1-630-378-3590) and was talking to their Tech Support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * (That's pound, star, C, star) This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Mar 17, 2008 | Sharp AL-1655CS Copier
Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Feb 07, 2008 | Heating & Cooling
Canon pixma mp150
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
