Question about GPS
E80 raymarine wiring diagram I have the rs130 gps antenna with wire kit but unable to figure out how to wire it to the e80
4 Suggested Answers
  • 111 Answers
SOURCE: cut antenna wire raymarine 300waas gps
That unit uses a TNC connector. Just have someone install a new one on the end of the cable. IT's a little more difficult than a F connector for a TV but not rocket science. You can also send it in to Mid-Shore Electronics. Just google them and get their number. They have alot of experience with the older stuff.
Posted on Oct 30, 2009
  • 43 Answers
SOURCE: GPS antenna
If your old antena is a Seatalk or NMEA antena you can use it for your C80
If you GPS antenna is older than five year change it.
Posted on Oct 31, 2009
  • 111 Answers
SOURCE: RAYMARINE C80 SEATALK CABLE INSTALLATION
The Raymarine RS125 has five wires and can be either seatalk or nmea. It would be best to get a dealer involved. If things are hooked up wrong you'll fry your equipment.
Posted on Jan 22, 2010
I have a old raymarine c80 navigation sometimes it gives me a fix when i turn it on and sometimes it will not. Do i need a new antenna if so what kind.
The issue is related to the antenna, either bad connection, low voltage or faulty gps. Start by checking the voltage supplied to the antenna (most probably through SeaTalk from the plotter), if you find this to be 11V or bellow - beef it up by adding external 12V. You can also check the wiring, if all looks ok - it is time to get a new gps antenna. Raymarine has a retrofit pack for the new RS130 which also includes SeaTalk ng converter. With some luck it's only the power...
Oct 22, 2013 | Raymarine C80 GPS Receiver
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
Cut antenna wire raymarine 300waas gps
Oct 27, 2009 | Raymarine Raynav 300 GPS Receiver
I just bought a raymarine c 70 with an evermore sa 320 gps, can anyone help with the wiring i have to do as i seem to have misplaced the instructions which came with the sa 320.
Hi
them works together nice !
connect SA320 green wire to RAY white and SA320 shield(black cover) to RAY green.SA320 red to 12 and black to ground(-).
Jul 21, 2009 | Raymarine GPS
Which wires to connect when connecting a marine antenna to a raycraft gps
Hi. I have G series Raymarine and I listen the noise when swtich on I am not shure , may be from the ventilation (the fan).
I not find troubleshooting to G raymarine, I hope find the soulatoin thanks.
regard
kareem
Aug 03, 2008 | Raymarine RL70CRC GPS Receiver
GPS antenna
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
Jun 04, 2008 | Raymarine C80 GPS Receiver
GPS Logo
125 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
