Question about Photography
Manual shutter release will not release after use
ML-L3 Wireless Remote Controller Shutter Release for Camera Nikon D5000
You need to set the release mode to one of the remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
See the "Release Mode" section of the manual (page 65 in my copy).
Jun 11, 2012 | Nikon ML-L3 Remote Control
I just purchased a Vivitar remote shutter release (wired) & the packaging reports that it fits the Canon 40D. I can't figure out out to insert the device to my camera. Can you help?
If there is telephone support, call them.
Other wise it may be that you have the wrong shutter release.
Your manual may be a help. Read it, for the shutter release.
Hope it works.
Jul 10, 2011 | Vivitar Cameras
Camera shuts off after pressing shutter
Manually turn off the camera, remove the batteries, press the shutter release a few times draining any residual charge. Replace the batteries give it a go. It the issue continues it well may be something wrong with the shutter release.
Jun 02, 2011 | Canon EOS Rebel 2000 35mm SLR Camera
The lag time for the shutter to operate after the shutter release button is released is very long. So long that the camera is really not usable to take pictures of anything that moves in the least. Any...
How long have you had the camera? It just sounds like the camera is in Manual mode or "M" and the shutter speed is set really slow. Try putting it back on automatic, or twist the dial that will increase the shutter speed. You can find the manual on Nikon's website.
Mar 21, 2011 | Nikon D100 Digital Camera
How do I set it up on my Nikon D60 to use this remote?
I assume you're referring to the ML-L3 infrared remote?
Select Release Mode from the Quick settings display. Select Quick-response remote. This will make the camera take a picture when you press the button on the remote. Well, almost. The same focusing and exposure metering delays occur as if you'd pressed the shutter release button.
You can also use the Delayed remote mode for group pictures. This gives you two seconds to hide your hand behind your back before the camera takes the picture.
By default the D60 will time out after one minute if you don't press the button on the remote. Custom Setting #17 allows you to set a longer interval.
Jun 17, 2010 | Cameras
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Instruction manual for settings on a Nikon F2?
Set the film speed with the dial on top of the Photomic unit. Lift the chrome ring and turn so that the film speed is next to the little red arrow.
Yes, the aperture is set by the lens ring. And if you have one of the older finders which uses the prong meter connection, whenever you mount a lens you must turn the aperture ring all the way to the highest number, then back to the lowest number. For old-timers, this is known as the "Nikon twist". It tells the meter system what the widest aperture of the lens is so that it can measure light properly at full aperture.
Yes, the shutter speed is set by the dial on top. The Photomic meter sits on top of it, so you read the shutter speed from the scale on the side of the Photomic dial by the mark on the back.
The other buttons on the front are the lens release button (left side as you hold the camera), DOF preview (button just under shutter release), mirror lock-up (lever ring around DOF button) and self-timer (long lever at bottom).
The T-L ring serves to protect the shutter release from accidental push. If you lift the ring and turn the mark to L, the shutter release is Locked. If you lift and turn to T, it prepares the shutter for Time operation, where the shutter remains open when released without holding the button down as you do at the B speed setting.
Finally, the most help: you can download the manual for free (donation requested, and worth it) at http://www.butkus.org/chinon/nikon/nikon_f2_photomic/nikon_f2_photomic.htm
Feb 08, 2009 | Nikon Photography
Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Dec 28, 2008 | Nikon D40x Digital Camera
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
Photography Logo
16 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
