Question about Car Audio & Video
Navigation software path
Eonon D5115ZU
I have an eonon g2112 but it didnt come with the bluetooth code. What is the code?
I had the same problem, but after much research was able to find it is 5802
Feb 10, 2015 | Car Audio & Video
When I pull up the gps for directions it says it cannot find program. Please set Gps path in file. What do I do to fix it.
Set GPS Path ..
On your Sylvania GPS go to System Setting > GPS Path .This function is to set GPS path for your navigation. Screen display will show asfollows:
File folders of TF card will be listed on screen. Click a folder to open it. Select GPSSoftware If there are two or more maps from different companies on an TF card, then thisfeature can help you select each of them easily. The way to Select: :In TF card directory,open the file folder to find the map to be used, select navigation software of .exe,(whichhas different names from each different company), then select andclicK 10_3_2011_2_45_46_am.gif icon, a dialogue frame will pop up on screen, as it shown below:
Click the accept icon to accept.
Click X icon on the upper right corner to return to GPS path interface.
Oct 03, 2011 | Sylvania SGPD430 GPS Navigator
I have a motevo gtvx2 and it said navigation software not found could you please get back with me soon as possible thank you
when you boot up your gtv-x2,there are 3 main icons,1 navigation2 setup3 entertainment
just goto setup>gps setup>
there is a path for navigation file.press the button and browse the navigation folder, find "garmin.exe" or your navigation software "XYZ.exe" file, select it.there you go!!!!!
Aug 14, 2010 | GPS
I have a eonon e1025 how do i hook up my subwoofer with two rca cables and only one rom the headunit
i have this problem to i have used a y splitter but how do you turn on the sub port in the software interface ?
Feb 24, 2010 | Car Audio & Video
Hi my eonon E0825 just told me that it has no navigation application how can i fix it we use it all the time
To be bluntly honest, the best thing you can do is buy another GPS: but spend the money on a good brand name like Tom Tom, Garmin, Navman, Uniden etc. Why? well I have two E0825 units and both have failed, one after approx 6 hours use it lost satelite tracking, and the second turned on once, and now wont turn on again. Purchase something that works out of the box, not something that requires days to charge like Eonon units do. Sorry for the negative answer, but just sharing my honest opinion.
Oct 30, 2009 | GPS
Where can I get the Updated Eonon E0851 GPS Maps
had the same prob and i downloaded the tom tom maps from torrent for free and the work
Mar 12, 2009 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
I have an eonon GPS/DVD/Bluetooth flip up touchscreen car stereo. Navigation works fine; when I swith to dvd or backup camera, unit screen shuts off.
Do you have the PARKING BRAKE ON??? You need to have the wire coming from the back labeled PARKING BRAKE hooked to ground. You also might have a radio damaged during installation. You can email me at eightballproaudio@yahoo.com, I am an unauthorized distributer of eonon radios...
Dec 12, 2008 | Car Audio & Video
My navlink gps says "not find navigation software"
If you haven't already fixed this; try going into, settings, navsetup, - this should give a Path of navigation software line, this line should read: '\StorageCard\iGO8\iGO8.exe' click on file icon at end of the path window "select storage card, select iGO8.exe, select tick to apply then exit.
This works for mine but I assume that if an alternative software is shown in the path window you must choose an approppriate .exe file in the storage card files.
Oct 28, 2008 | GPS
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
