We need to determine where the leak is...
Unplug it...
Start by removing the water resevoir...dry out what you can with paper towel...
flip it over on a table with a bath towel. Take off the metal bottom plate
you can then check for water inside the unit.
since you didnt say where the water is coming from... the K-Cup arm or the bottom...
I will assume the bottom is where the water is coming from.
Hoses on these units are fastened with 4 inch "Ty-Wrap" nylon fasteners.
You may have a broken one, and need to replace one... hopefully it is located on the bottom between the water fill and the main water motor... which you shouold be able to see when the bottom metal pan is removed...
If the water is coming out from the top. then I suspect hot water expansion is bypassing one of the valves, or there is a nylon strap/hose combination you cannot see instde the unit...
Hopefully it';s the bottom
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/lisa_52daba487e5b4d53
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How old is your unit?
