Question about Emson Super 2079 Mechanical Sewing Machine
Replacement needle Needle #14DHx1
    Problem Solver:
  • 5 Answers
I have replacement needles for an Emson Super Sewing Machine.
Posted on Oct 18, 2014
I need an automatic needle threader for a Brother NS30 Le
Fixya does not sell replacement needle threaders.
Aug 05, 2016 | Brother Sewing Machines
Remington stitch mate
Hi Bobby B,
Do you just need new sewing machine needles? There are so many types it is dizzying. Go to a place like Hancocks, Joann's or Hobby Lobby. They will be able to help you. Nearly every type of fabric has a needle that will work the best with it. Good Luck! The needle most used is a 80/12. That is the standard needle.
Apr 13, 2014 | Sewing Machines
Replace needle on a Huskylock 905
Look in your owner's manual for needle replacement procedure. You have to unscrew the small screw holding the needle.
Be careful that the new needle is properly seated before screwing it tight. Otherwise, you might end up with it slightly askew.
Apr 01, 2014 | Husqvarna Huskylock Computerized 905
Need a Replacement Needle Clamp for a White 1866
try these 2 sites,, ask them by calling them or email them
about the needle clamp screw
sewvacdoctor.com
a1sewingmachines.com
Sep 21, 2012 | White Sewing 1866 Mechanical Sewing...
How do I change a needle on a Janome jl-634
The jl-634 is a serger so should have two needles. There are two small screws (one on the left and one on the right) of the needle bar. First raise and remove the presser foot (makes changing the needle much easier) Rotate the needle bar to its top most position. Loosen the small screw for the needle you wish to replace, do not unscrew it entirely as it is finely threaded and difficult to re thread. Remove the needle while observing the orientation of the shaft (which direction does the flat side of the shaft face) Insure that replacement needle is correct for your machine. Serger needles are usually different from standard sewing machine needles. Insert new needle with correct orientation, and re-tighten the small screw previously loosened. Reinstall and tighten presser foot. Rotate machine through entire stitch cycle to insure that needle does not strike or rub on anything. Re-thread needle and check for proper operation.
May 06, 2011 | Sewing Machines
Needle size replacement. I ran out of spare needle for my Brother XL-5500 sewing machine. Does anyone now the size and model of the replacement needle? thanks
. Schmetz is excellent, Singer etc. Needles all work in the machines but most of your sewing will be done with an #11, but denim, for instance will be at least a #14, #16 depending on what you are doing. Buy an assortment of sizes, sharps for regular and ball point for knits, they are very inexpensive. Do not keep a dull needle in your machine, throw away old and start every new project with a fresh one.
Sep 08, 2010 | Brother XL-5500 Mechanical Sewing Machine
What happens if the needle breaks?
Extra needles came in the accessory bag. Just unscrew the screw above the presser foot, remove the old needle and put in a new one. These are common sewing machine needles,but the LS2125 will also handle dual needles. There are numerous videos online that show how to do this.
May 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Need replacement needles
alI it takes the exact same needle as a home sewing machine (130/705H or HAx1 or HAX1SP) needle. Nothing special. Don't use a needle smaller than an 80 in aserger for best results and flat side to the back
Mar 21, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Mar 29, 2008 | Singer 7422
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Emson Super 2079 Mechanical Sewing Machine Logo
Top Emson Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you an Emson Sewing Machine Expert? Answer questions, earn points and help others
