Question about As Seen On TV Swivel Sweeper Vacuum
Cordless swivel sweeper g2 brush roller back together
Swivel sweeper brushes slow with full charge even after cleaning brushes
When you say you cleaned out brush's are you talking about the build up between the bristles? I've found that I have to take the roller completely off and use fine needle nose tweezers to actually get all the stray hairs and caked on dirt as it hides close to the inside of the brush rollers. It's a bit more work to do this but I think you might benefit from this extra step!
Good Luck!!!
Jan 23, 2013 | As Seen On TV Swivel Sweeper Vacuum
Hoover linx cordless bh50010 brush roller not turning
Simple!
Pull brush assembly from the handle.
Remove brush and belt, unscrew ALL screws at the bottom, separate parts, and to your surprise, you will see broken wire leading to the motor. Bad workmanship during assembly leads this wire to be twisted and cut by the plastic parts allowing swiveling. Be prepared to have some hard time setting motor in its place.
Oct 13, 2011 | Vacuums
Little suction at all through the bottom sweeper but the hose is powerfull still..took apart,,spent real time,,new filter and all..still no luck. please advise.
Is the brush/roller spinning? If not, then the connection between the roller is broken, it is a two piece roller connected by a round black piece. there is a gear under there that can break and keep the roller from spinning together.
Mar 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc15 animal vaccum ,the roller o brush won't run, what can i do, luzelenamorales@live.com
Take it apart and I bet you find a broken belt,replace belt from sweeper shop ,put back together and on your way
Feb 17, 2011 | Dyson DC15 Animal Bagless Upright Cyclonic...
Brushes don't turn, light works when switched on, battery fully charged
Hello. Generally, when the brushes don't turn you will find that the belt is broken. In some cases, also the brushes will stop if they are clogged up with animal hair, etc. Regards, Joe
Dec 14, 2009 | As Seen On TV Swivel Sweeper Vacuum
Roller brush doesn't turn
Sounds like the belt is maybe slipping did it brake the new belt as well?
Mar 10, 2009 | Vacuums
Brush roller will not turn when I star to sweep.
maybee there is hair in it, do u know how to fix a psp that doesnt read games
Jan 15, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Battery or ?
If this model is under 1 year warranty, I would suggest that you take it to a warranty repair shop or that you ask for a replacement. with a Return Material Authorization (RMA) at no further cost to you for shipping.
Jan 10, 2009 | Hoover H3030 FloorMate SpinScrub 500...
I have a Dirt Devil Swivel Glide Vac with a broken belt. I have purchased the correct belt(#4).The bottom is off and I cannot tell where the belt connects to. Please help. Jann
it connects to the left side with the little metal rod sticking out.then connect to the wooden roller. in the space without the brush on it. roll the wooden piece to check if everything moves. then put back together.
Aug 27, 2008 | Dirt Devil Vacuums
Vacuums Logo
14 people viewed this question
Top As Seen On TV Vacuums Experts
JoeVacs
Are you an As Seen On TV Vacuum Expert? Answer questions, earn points and help others
