Question about Avaya 4690IP Audio Conference
Gurgling sound from phone
My phone - on a conference desk in my office - continually makes a gurgling sound. I refer to it as my percolator that never produces coffee.
I need three of these desk. Help
http://www1.macys.com/shop/furniture/home-office-furniture/Furniture_category,Sortby,Productsperpage/Desks,ORIGINAL,40?id=35422&edge=hybrid&cm_mmc=Google_DMA_Furniture-_-Furniture+-+Generic+-+Home+Office+Furniture+-+Mod+Broad_Office+Desks-_-48380724084_Broad-_-%2Bhome%20%2Boffice%20%2Bdesk_mkwid_s5MHUXXEp'dc_48380724084%7C-%7C5MHUXXEp
Sep 23, 2014 | Martha Stewart Home Office Tyler Desk,...
Panasonic kx t7436 how many conference will do conference
you can do as many conferences as you have phones, but one phone can have one conference at a time with 3 total parties(depending on your phone system) in the conference (so yourself and 2 other people, inside or outside of the office)
if you have a TDA/TDE/NCP phone system (blue box on the wall or in a computer rack) you can have 5 people in a single conference...
if you have a TD phone system (white box on the wall) you are limited to a 3 party conference
Jan 06, 2011 | Panasonic KX-T7436 Phone (KXT7436000000)
Avaya 4690 just flashes red lights and makes a click sound when booting....over and over again Nothing shows on the screen. Was working fine, just moved it from one office to another... now will not boot
This usually means the phone is not receiving enough power. You either have a power issue in the electrical of the new room or the power adapter is not functioning correctly. Try plugging the phone back into the old office to see if it comes up correctly, if it does their is some sort of issue with the electrical supply in the new room. If you have another conference phone try using that power adapter on the non-working phone.
Dec 14, 2010 | Avaya 4690IP Audio Conference
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Dec 07, 2009 | Nortel Norstar 16-Line PBX Speakerphone
My Farberware coffee maker starting making a high
Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
Sep 21, 2009 | Faberware 2-8 Cup Percolator
No mute - conference calls
sounds as if you will need your vendor to program your phone and others that need be to have Handsfree/mute capabilities.. i assume since you can not mute then you can not place your phone on Handsfree either.
May 29, 2009 | NorStar Meridian M7310 Phone
Polycom sound station 2 conference set conference problem
sounds strange, it lookslike a main board problem, considering that u have been using similar unit before.there is not much that u can do from the menu options.u will have to refer ur vendor for rpairs
Jan 15, 2009 | Polycom SoundStation 2W (2200-07800-001)...
Time restriction on conference calls.
If this hasn't been solved, I am a certified Vodavi tech. Give me a call
Oct 29, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Conference call when connected to other internal lines
First dial a number,while talking to that person dial another number, after dialing the another number press redial button,than you can talk to another person but the the first line i.e. the the person you are talking at first will have to wait, he will not be able to hear waht you are talking with the another.in order have a conference than again press re-dial button than you will be able to have a conference.....
Jul 21, 2008 | Panasonic KX-T7730 Corded Phone
Avaya 4690IP Audio Conference Logo
20 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
