My washing machine won't do anything and is making a buzzing noise
5 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: Kenmore 70 series washing machine
Does not agitate, does it spin? If it doesnt you have a coupler failure. If it does spin then the agitator dogs have worn to the point of no return.
This is the link for a coupler;
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=278912&PPStack=1
The coupler is accessed by pulling the machine out 2 feet and tilting it back to expose the bottom of the machine. Once done follow the pump( has two hoses attached) to the motor and after that is the gearcase. Between the motor and the gearcase is a coupler. There is a small gap between a black plate where the motor attaches and the gearcase.Reach from front to the plate and feel behind it up in the gap. This is where the coupler is and if you feel soft spots or if you try to rotate it and it separates get a flashlight and a friend to spot hold the machine while you crawl under to look at it. You need to look at the white flanges for cracks and push on the flanges while checking. If so this machine is designed to be an easy fix. The pump removes by popping the clips top and bottom as well the motor with the addition of 2 1/4 inch hex screws and a wire harness plug( may have one to three additional wires for a capacitor and a switch, two red and a white wire). Once the motor is off you can see better as to what the damage is... If the coupler falls apart upon removing the motor finish removing it from both sides. When replacing I use a 9 inch extension and a deep well socket about 1/2 in size to seat the flanges flush to the motor and gear case shafts using a small hammer not hitting to hard.
This is the link for the agitator dogs;
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3109&PPStack=1
For the agitator a sure test is to reach in and rotate the agitator back and forth, it should only go one direction, if it is free then this is the problem.
The dogs are below the softener cup on the agitator,when removed you will see a seal cap that has to be removed. After this you will see a round insert with a 7/16 or 1/2 inch bolt attaching it to the gearcase spindle. once out the agitator assembly will pull out separating into a lower and top half. The top if turned upside down will dump the contents of the agitator dog assembly. These are simple to replace and if there is no retainer, a little vaseline will stick them long enough to re assemble, just watch how they remove and note any fins and notchs use between the upper and lower halfs to align them.
Posted on Sep 20, 2008
michiganfan9
  • 179 Answers
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
torres No9
  • 27 Answers
SOURCE: Model EWF1087 washing machine will not spin or
your pump impeller is blocked or fouling on something inside the filter compartment,turn machine off unscrew fiter (be prepared for water to come out),then get a long screwdriver and turn the impeller anything caught in there will free itself up,and you should be able to mremove forieghn object if impeller doesnt turn then it more than likely your pump is seized and will need replacing hope this helps.
Posted on Oct 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: My washing machine works fine
Welcome to FixYa.
Based on what you`ve described, it sounds like perhaps there is an obstruction in the pump...or perhaps the pump is indeed seized/failed.
I would first check the pump for obstructions.
**Unplug the washer or turn off your breaker before servicing the washer...safety first**
To clean the pump on your washer, If you direct your attention to the bottom right side of your Bosch you'll see a small round cover like so...
With the aid of a small screw driver, knitting needle, or anything small enough to fit in the small hole in this cover...
It will push in a tab, it doesn't take much force.
Rotate the hole (clockwise) to 6'oclock and it should come free, the edges are very sharp so be careful.
Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green or red ring attached to a metal clip on the pump, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. There is potential for a lot of water...even if the washer looks empty.
Now pull out the trap/filter and visually inspect the inside of the pump as well as the filter/trap.
That is how you gain access to and clear the filter on your Bosch washer.
If this was the problem, awesome. If not let me know and I`ll try and help further.
Hope you found this helpful. If so please take a moment to write a short testimony and leave a rating.
Thank you for choosing FixYa, good luck.
Regards,
Macmarkus :)
Posted on Sep 10, 2010
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
Wont do anything
See if the buzzing is coming from the timer, it may be broken. Try to change the timer to spin and see if the motor works.
Dec 02, 2013 | Maytag MTW5700TQ Top Load Washer
Washing machine won't empty making buzzing noise and coming up with f.05
looks like your drain filter is clogged. There could be cents, matches or something like that. All this stuff do not let to spin drain motor clearly.
Apr 13, 2013 | Washing Machines
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
Washer fills, agitates, won't spin. Makes buzzing noise. Amana LWA50AW
Most likely it could be the forward belt . When the machine is under load you hear a winding noise it sounds like the pulley belt tensioner. One other thing to check the rinse and hold button is activated as in the past accidentally people have switched it off.
Jul 26, 2011 | Amana 3.2 cu. ft. Top-Load Washer
When u start it it just make a buzzing noise but doesnt fill with water
Hi, if there's no water at all, make these checks:
Is there water getting to the machine?
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 13, 2011 | Washing Machines
When I turn my washing machine on, it makes a buzzing noise and will not operate
One common failure is the water flow valve that is part of and behind the hose connections. These will buzz and not allow water to flow or will allow only one or the other water line to supply water. Most machines refuse to do anything until enough water is present.
May 15, 2010 | Hotpoint VBXR1090D Top Load Washer
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
