Question about Blakeslee F-20-CA Stand Mixer
Blakeslee planetary mixer model f-20 vf instruction manual in french
  • 110 Answers
SOURCE: will hobart 20qt hook fix on a blakeslee 20 qt
as long as the shafts are the same o.d.and the bayonet pin are the same diminsions you should be ok
Posted on Jan 14, 2010
  • 10 Answers
SOURCE: Looking for a dough hook and bowl for a blakeslee
Blakeslee is still around phone # 1-708-656-0660
Posted on May 25, 2010
SOURCE: I inherited a Blakeslee mixer model # A717. There
i have the manual i can email it to you! macheson@gmail.com
Posted on Nov 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a blakeslee cc15
Hi and welcome to fixYa, I am Kelly
This is the US support site for Blakeslee.
http://www.hfse.com/GetYourPart.html
Call 800-458-5593 or Fax 800-800-4981
They also have a Canadian site.
The link below has a live chat feature where you can ask if they carry parts for the CC15 model:
http://www.hfse.com
Hopefully this will get you a source for your hook.
Thanks for choosing FixYa,
Kelly
Posted on Feb 23, 2011
jyackle5
  • 8197 Answers
SOURCE: I am looking for the
To get parts for your Blakeslee Plese contact Blakeslee on the link below.
http://www.blakesleeinc.com/replacement_parts.html
Posted on May 13, 2011
Manual for model a717 blakeslee mixer
Try Googling (Blakeslee)(a717)(manual) without parens.
Mar 26, 2018 | Blakeslee Food Mixers
Blakeslee Uni mixer model A702 I moved the lever (front top) side to side and it appears that the mixer is now out of gear. not sure what I did miixer worked great before that?
These machines were designed to disengage the gearbox when the cover (where the blender goes) is removed, the theory being less gear train resistance more power to spinning knives/blade. Is this the cover that you are referring to?
Jan 07, 2015 | Blakeslee Food Mixers
What kind of oil use this
I came across a manual for a Blakeslee f-40 60 80 and here is what it said. Hope this helps
Lubrication
The planetary and spiral-beveled gears are self-lubricated for life. The lubrication used is micromly grease and must be re-applied if gears are replaced. The transmission uses Mobil "delvic 1" synthetic oil which should last the normal life of the mixer. No lubrication is required for the auxiliary drive hub.
If lubrication is applied to the auxiliary hub a grease-like substance will possibly leak out causing damage to the product.
Applications of any lubrication will Void Warranty.
berkelsalesservice.com/PDFs/DD-40_60_80.pdf
Jun 27, 2011 | Blakeslee F-20-CA Stand Mixer
I have a blakeslee cc15 i need a hook .is there any part for this mixer
http://www.hfse.com
Kelly
Feb 23, 2011 | Blakeslee F-20-CA Stand Mixer
Planetary gear housing fell off.
Hi BHENDERSON_C, sorry to hear about your mixer’s malaise. The Planetary should not fall off! Something has failed inside the transmission housing to allow the planetary to drop from the head. It may not be evident from the planetary assembly, so you need to get ‘under the hood’ to find the point of failure.
It would be helpful to have the correct Parts List manual on hand when you start to disassemble your mixer. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case, KP2671, and for starters, select the last file, KP2671XWH3.pdf (325.07 KB), of the 24 listed under Parts List (24) (NB: There are five different model versions of this manual, so check to see that it matches your mixer model. If it doesn’t try a different version).
To disassemble your mixer you will need a regular and Phillips screwdriver, snap-ring pliers, a small drift pin punch and a small hammer. By using the exploded views in the Part List manual, you should be able to disassemble, inspect, identify and replace broken/worn parts, and reassemble your mixer. The Parts list manual doesn’t provide that step by step assembly instructions that would be nice to have, but just a general idea of how all the parts fit together.
Turn to pages 4 & 5, titled: “Case Gearing And Planetary Unit” which shows you an exploded view of all the mechanical parts and assemblies for your mixer. You will need to remove the Transmission Housing and remove all the grease from around the gears to clearly see the parts. Inspect the grease for debris. I expect you’ll find pieces of the retaining clip and retain pin that hold the planetary to the mixer head somewhere in the grease.
After you’ve determined which parts failed, you will want to order replacement parts. Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Also, here are links to three excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, troubleshoot, determine appropriate repair parts and reassemble your mixer to get it working again. Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! – hslincoln
Feb 26, 2010 | KitchenAid KP2671 Professional 6 Series...
Will hobart 20qt hook fix on a blakeslee 20 qt mixer.
Dec 09, 2009 | Blakeslee F-30-CA Stand Mixer
My older blakeslee mixer model b12 needs oil
The B-20 takes 50 SAE HD oil. I noticed that it doesn't stink like gear oil but is still pretty goopy. I think Mobil 1 Delvac is suggested. I think 30 weight would be fine for your machine, as well.
Jun 09, 2009 | Blakeslee F-20-CA Stand Mixer
Blakeslee A717 speed control
where are you from, i have phone number to agents that still provide support for A700 series.
Jun 28, 2008 | Kenwood KM305 Stand Mixer
Blakeslee F-20-CA Stand Mixer Logo
Top Blakeslee Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Blakeslee Food Mixer Expert? Answer questions, earn points and help others
