Question about Compaq Inkjet IJ650 Printer
My printer keeps printing things how do i stop it
How do I stop my printer from printing memory clear report? so it can print.
Sign-in into printer (check the OM) and push "Stop Printing" or "Clean Printing queue" - depending on model.
Feb 19, 2015 | Canon Pixma Mx432 - Multifunction Fax /...
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
When I finnish printing it keeps on printing and i cannot stop it
First thing you need to check is if you are using the right printer driver. Printers emulate in different languages. If this is a Panasonic printer you can press the Print Key and access the Job Control, the Job Queue, then print, then enter 0000 and delete job.
Dec 30, 2009 | Office Equipment & Supplies
GREEN LIGHT KEEPS FLASHING ON MY PRINTER
Green light flashing means printer is in printing process. No problem. If you want to stop printing. delete printing job from printer properties or stop printing from status monitor.
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer keep printing the same thing
turn the power off wait for a few hours try printing the same thing that what you were trying to print again if that doesnt work try to see whats under the hood of the printer
Jul 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
I bought a printer from Btother MFC3360C. The paper didn't feed. I attempted many times to get it to work by trying to print some things. I finally fixed the paper problem and the damn thing starts pr
those buttons dont stop whats in the queue. You need to go to your printer icon, right click and select the first tab on the list, from there, you will see all the files being dumped to the printer, right click file and select delete, this will erase everything in the buffer.
thanks adi
Apr 24, 2009 | Office Equipment & Supplies
I was printing some long documents from an email and printing them in triplicate. Evidently I must have hit a wrong button as I have printed everything but the printer just keeps printing everything over...
Choose the job reset button on the printer. If this does not work go to your printer folders double left click the printer in question and delete print jobs listed . good luck
Oct 17, 2008 | HP Office Equipment & Supplies
Test Page
thats not the test page that is allignment page which is printing.
keep the the printed side of that page which comes out on the scanner glass.press the ---scan ---button.the on /off light will blink, wait till it stops blinking.and after that everything will be normal.
for any thing else let me know.
thanks.
Sep 17, 2008 | HP LaserJet 1200n Printer
Compaq Inkjet IJ650 Printer Logo
13 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
